Pics of my Vert install
Old May 6, 2001 | 10:27 PM
BOOSTD 7's Avatar
Persona non grata
Finally, here are some pics of the install in my '90 Vert. I did it all myself...
It consists of:
Nakamichi CD-45Z HeadUnit
CDT Audio HD-642DT 3 way, 6.5" component set
OZ Audio 10" DVC sub
Precision Power 4200M running at 200x2 for components
Adcom GFA-4402 running at 300x1 for sub
I bought an Aura MR-675 amp to replace the two amps and run the whole system. It's rated at 70x6 I think, bridges to 180x3 - but is way under-rated, so it's more like 250x3. It has built in crossover/eq.
I might also replace the sub with something else. Like maybe a CDT sub, or an A/D/S or Focal sub.
Old May 6, 2001 | 10:29 PM
BOOSTD 7's Avatar
Persona non grata
More pics...
Old May 8, 2001 | 12:40 AM
BOOSTD 7's Avatar
Persona non grata
Originally posted by Cypher_II:
Kewl. How is the staging with the components setup like that. I've been looking at my doors wondering where I was gonna fit 3 spkrs.
The Nackamichi head unit is killer !!!
Thanks... The imaging is about as good as it's going to get in an Rx-7. You might be able to do better by mounting the tweets up on the corner of the dash, and the 4"'s in the dash. But I think my way gets a lot louder. Plus the verts' don't have 4's in the dash, so I would have had to do a lot of custom work, like make a fiberglass pod or something. Actually, I think the image turned out very good. A little left/right bias though. I asked my wife to sit in the car with her eyes shut and point to where she thought the sound was coming from. She pointed straight forward I said, right answer...
I like the Nak. My first one was a lemon. It skipped a LOT and wouldn't play CD-R's. So I returned it, they gave me a new one and installed it. Now it works fine. Plays anything I throw at it.
I've been thinking about buying a DSP that can do time alignment - otherwise known as putting a delay on the channel. That would help move the soundstage out a little and equalize it. Although it sounds so good right now I can't complain.
I'll have pics of the amp/wiring install soon. Right now it's kinda half-assed since I'm putting the new amp in later this week.
Old May 8, 2001 | 02:58 PM
91vert's Avatar
I am going to have to come over and take a closer look at that setup. I need a serious sound upgrade in my vert and that looks pretty awesome. I was afraid of putting in some aftermarket head unit because I thought it would look "out of place" in that great big opening, but yours looks real clean.
Old May 8, 2001 | 03:33 PM
BOOSTD 7's Avatar
Persona non grata
Heck man, come over tonight. Give me a call on the cell at 314-780-2792.
I got the Nakamichi partially because it doesn't look out of place. It has kinda the same look as stock, and it has some of the best sound quality of any unit on the market. And if you're worried about losing the headrest speakers, don't worry...you'll never miss them. Come over for a listen and I'll show you what I mean.
Old May 17, 2001 | 10:39 PM
BOOSTD 7's Avatar
Persona non grata
Originally posted by BOOSTD 7:
More pics of the Aura amp, crossovers, and my unfinished wiring. Taken at night, so it's kinda dark. The passenger side crossovers are mounted under the glove box.
I just kinda have my mind set on the EVO's, even though I've never heard them. The mass and DD stuff needs more power than I'm going to be giving it.
I'm located in St Louis...
Old May 18, 2001 | 12:59 AM
BOOSTD 7's Avatar
Persona non grata
I got the Aura amp hooked up... noticed a nice improvement. I seemed more open that the other amps. Bass was punchier too. I was actually worried because the damping is rated at 60, which is low. But it runs the sub just fine. The components get loud enough to make your ears bleed now!
I'll probably build another box, try to stuff a full 1 cu/ft in there. And then get an Audiomobile EVO 12" for it. The OZ is one of the best sounding subs I've heard, but it just doesn't get loud enough for a vert. It would be great in a hardtop 7. The EVO 12" has been known to hit over 125db by itself...with my 250 watts I would bet I can hit 120db with it That should be loud enough!
More pics soon....
Old May 18, 2001 | 08:37 AM
BOOSTD 7's Avatar
Persona non grata
So where are you located?
I've heard a lot of good things about the DD stuff. But I have a couple problems. First, they only make dual 4ohm vc's. My amp could handle running a 2 ohm mono load if the vc's were slightly above 4 ohm each, but theirs say 3.7 each... which would be pushing it. And I definately don't want to run them in series. I saw a review of the EVO that showed that their 3 ohm coils were actually more like 6 ohm, and in parallel they were 3.7, which would be a perfect mono load. Plus the DD stuff is just plain ugly!
Old May 18, 2001 | 01:09 PM
dnewman's Avatar
I don't think that Nak are known exclusively as the best SQ units out there. Don't get me wrong, they are very nice, but the top of the line units from eclipse, alpine, sony, clarion, and mcintosh will have equal or better SQ in some cases. Besides the difference between all of these HUs when used with the same speakers and amps would be neglible if even noticeable at all.
BTW, most speakers have a DC resistance that is lower than the published specs. Most 8 ohm woofers (impedance) have a 5.7 to 6.7 ohm resistance. You should be safe using the DD woofer. I would encourage you to look elsewhere for a good SQ woofer, though.
btw, good job on the install, looks great!
Old May 19, 2001 | 03:09 AM
T2's Avatar
T2
this may be a biased opinion but i reckon not many 12 inch subs can touch these guys in punch....
look at the surround....1 inch baby =D
and the SQ is quite good......
not as good as the DDrive subs tho
DUH
87T2
Mods:
Microtech MT8 ECU
3' Mandrel Bent exhaust
High Flow 3' stinky cat
5' SS Tips
K&N long cone filter
Custom Made BOV
Electronic Boost Controller on 6psi\12psi
173Hp @ 6200 RPM RWHP
at 12psi on a hot day
coming soon:
Large Front Mount IC
Bigger Fuel Pump
Bigger Injectors
Inlet Mod with K&N in front section of bumper for cold air induction
Stereo: *ooh baby*
Pioneer PH8250 HU
Alpine SPR 175a splits
Alpine SPR 172a Coaxials
2 x Alpine 12' Type R's
Lanzar Vibe 900 watt RMS
Pionner Stacker 6
Coming Soon
Lanzar Vibe 900 watt Amp (another)
Lanzar Vibe 240 (for full range spkrs)
two more Type R's
0 gauge Cable
Phoenix Cap
Old May 22, 2001 | 01:14 PM
dnewman's Avatar
Not that I doubt your subs are nice, they probably are very good, but a 1" or 2" surround in some cases have very little to do with the output, or the quality of a speaker. I've seen a 1.5" surround on a 10" with a 7 mm xmax. All it would accomplish is making the radiating area smaller and taking away sensitivity.
And, I'd probably take my $119.00 Shiva over anyones sub in here regardless of price. And I would definitely keep my 199.00 Lambda Acoustics subs over anything on the market at any cost.
Old May 24, 2001 | 10:34 AM
asherwood's Avatar
Nice install, and by the looks of it a great component set for the front! I was thinking of a similar setup and was wondering how thick the MDF spacer was that you used for the 6-1/2" speaker?
Unfortunatly I have not seen that brand sold locally, so I may gave to piece my own set of parts together...
Al
Old May 29, 2001 | 05:25 PM
OneBadRx7's Avatar
Lucky
Exclamation
T2, dont take this the wrong way but if you think you have the best 12" subs for punch then I am kinda doubting you have listened to many woofers in your day. What are those anyways, they dont look familiar to me at all. Also the surround has nothing to do with output, look at some of those generic companys out there coming with like 2" surrounds on their $100 woofers, does that mean they are better, I highly doubt it. Anyways, I havent heard your subs but there are just too many subs out there for one person to say they have the best. My (2) 12" square Solobarics hit 149.5 db in my first run, with the subs being brand new and not broken in. I will have install pics soon, its looks pretty damn good!!
Steve
OneQuickRx7@hotmail.com
93 CYM R1
Pettit 3" SS downpipe
Pettit 3" SS catback
APEXi Power Intake
Tokico Illumina shocks
Boost & A/F gauges
99 tailight conversion
Silicon hoses(soon)
Kicker sound system
Old Jun 5, 2001 | 08:42 PM
OneBadRx7's Avatar
Lucky
Lightbulb
Oh and one more flame, your tweeter location sucks, shitty imaging is coming your way, later
Steve
93 CYM R1
APEXi Power Intake
Boost & A/F gauges
Silicon hoses(soon)
Kicker sound system
Old Jun 6, 2001 | 08:10 AM
dnewman's Avatar
Why rip on everybody's system? If they are proud of it, don't try to cut them down. If you want good imaging get a nice home system. Trying to acheive good or great imaging in a car is very difficult and expensive.
Old Jun 8, 2001 | 10:06 PM
OneBadRx7's Avatar
Lucky
I do have a nice home theatre system actually. Also I was kinda harsh, I shouldnt have said it sucked, I should have seen it was less than ideal, my bad. Sorry for coming off so strongly,
Steve
Steve
93 CYM R1
APEXi Power Intake
Boost & A/F gauges
Silicon hoses(soon)
Kicker sound system
