How to fix the coolant buzzer even with oring failing
Old May 15, 2003 | 10:03 PM
pomanferrari's Avatar
First picture
Old May 15, 2003 | 10:20 PM
Background:
Missing coolant, no white smoke, no hard starting since last June, coolant buzzer going off, not pulling coolant back into the AST.
Blockweld 3 times. Seems to hold until I decided to run 15 psi on primary and 14 on secondary using datalogit with PFC.
Started getting the buzzer again and coolant not pulling back.
Solution:
Volvo S70 AST tank 1.5 qt capacity. $50.00 from dealer. The same set up as BMW, Benz, Ferrari, VW, Audi, Volvo.
True AST as the combustion gas travels thru the yellow line from the top of the filler neck into the Vovlo ttank and the air from inside the radiator percolates up from the botton of the radiator.
The cap is a 19psi and when the car is hot, you can hear it vents combustion gases but there is sufficient capacity in it that I don't have to refill it for a week at a time.
Being the cheapskate that I am, I want to see how long I can go before I'm forced to put a Malloy reman in. This thing has been running with the o-ring problem for the last year (8000 miles). So how can you say these cars are unreliable? Especially at 14 psi.
Old May 15, 2003 | 10:29 PM
Old May 16, 2003 | 12:33 AM
Good job.
I was thinking samething when I blew my engine.
but I got the engine rebuilt instead.
may be next time I'll try..
The1Sun
Sep 18, 2015 07:13 PM
localized
Sep 16, 2015 12:18 AM
The1Sun
Sep 15, 2015 04:45 PM
86glxNA
Sep 15, 2015 04:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
