O2 Sensor Help???
Old Nov 19, 2009 | 06:48 PM
young Dizzy's Avatar
1987 Rx7 Turbo2
O2 Sensor Help???
When i brought my rx7 not 2 long ago the guy i brought if from said that it needed a o2 sensor cuz it runs really rich with out it. So i brought one and put it in but i cant find the other end that plugs into the engine i dont think it there but the guy said it is. Where would this plug on the engine be?
Old Nov 19, 2009 | 09:04 PM
w.sen's Avatar
In a Bucket
What year?
S4 is near the rear of the motor on the passenger side .
Old Nov 19, 2009 | 11:36 PM
gracer7-rx7's Avatar
needs more track time
Originally Posted by w.sen
What year?
same thing on the 3rd gen.
look for a black plug hanging around back there.
Old Nov 20, 2009 | 11:52 AM
w.sen's Avatar
In a Bucket
S4's is like a greenish plug. Single wire connection.
Old Nov 20, 2009 | 12:55 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Profile lists an '87 TII, so I'd assume S4 is the right guess. As mentioned, it's a green plug with a single black wire. It comes off the harness near the primary injectors, and loops behind the intake manifold on the passenger side.
Old Nov 20, 2009 | 06:34 PM
w.sen's Avatar
In a Bucket
acually i went and looked its a brownish plug.. i got my uim off
Old Nov 21, 2009 | 01:18 PM
Top Down, Boost Up
Yeah, sometimes they're brown/tan. I've seen that on some engines too.
Old Nov 24, 2009 | 03:48 PM
1987 Rx7 Turbo2
man i been lookin all over i really cant find this **** i gotta find a pic of where it would be cuz i dont even think its there
Old Nov 24, 2009 | 07:36 PM
badpescado's Avatar
all i can offer is this: http://www.rx7city.com/89-91manual.htm maybe you can get the 86-88 manual at the same place? im not even sure if they are different?
Old Nov 24, 2009 | 11:09 PM
rxtasy3's Avatar
if u had to unplug the one u took out, how can u not find it now?
Old Nov 25, 2009 | 11:54 AM
Top Down, Boost Up
^ It sounds like the previous owner sold the car without an 02 sensor installed.
It's likely someone broke/cut the plug off, or it's hidden under the UIM now. If all else fails, you can run a new wire directly from the ECU, through the firewall & to the 02 sensor.
Old Nov 27, 2009 | 03:02 AM
1987 Rx7 Turbo2
well i think if i unpluged it i would know where its at thanks,, but i found out that he cut it so i ran it to the ecu
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
