Group Buy & Product Dev. FD RX-7 Post your possible Group Buys and product interest for the 1992 through 2002 FD series RX-7 in this section.
Group Buy AtomicRex Adjustable Rear Arms
Old Nov 16, 2009 | 03:22 AM
AtomicRex's Avatar
As part of our continuing desire to build the ultimate race car, we have designed and manufactured our own rear suspension arms (lower arm, trailing and toe links)
The lower suspension billet arms are made in 5 pieces:
Inner arm
Centre piece
Outer arm
2 lock nuts.
The centre piece uses both a left and a right handed thread, so once the lock nuts are slackened (using the supplied spanners), adjustment is made by simply winding the centre piece in or out. This not only gives you the facility to change geometry settings very quickly but also an infinite number and accurate set of adjustments.
The lower arm has 3 spherical bearings, with retaining clips, and is attached in the standard manner. As the OE arm is attached into the subframe using a camber bolt, we have manufactured a set of laser cut plates which slot into the original camber position and centralise the hole. Each bearing has a set of individually machined spacers to compensate for the standard bush.
The billet trailing arm is attached through the middle spherical bearing and a rose joint into the chassis with individually machined spacers. This is once again fully ajustable.
The toe link is a simple yet effective arm that has a left and right handed rose joint either end. These come complete with individually machined spacers and lock nuts.
The kits are either anodised or powder coated to give a durable and long lasting finish so as to prevent any corrosion.
We are looking to supply the kits in one of three forms:
1. Complete with a motorsport grade bearing. £960
2. Complete with a fast road grade bearing. £850
3. Without any bearings. £350
I can offer 10% discount on a collective of 5 orders.
Let me know your thoughts.
Old Nov 16, 2009 | 04:32 AM
Gringo Grande's Avatar
1.5 Goodfella's Tall
Every time I see a post regarding a new product from you guys I get weak in the knees. Good stuff my friend, good stuff!
Old Nov 16, 2009 | 07:55 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
very nice.
howard
Old Nov 16, 2009 | 11:01 AM
paul_3rdgen's Avatar
Too cold in the garage
Nice work. Would this eliminate the stock pillow ball bearings that cause the rear clunking?
Old Nov 16, 2009 | 11:47 AM
AtomicRex's Avatar
It will elimate everything Mazda for the lower arm, trailing arm and toe link. It will still retain the upper arm with along with its pillow ball bearing. But eliminating 2 is certainly worth a start
And thank you Howard for your compliment The same goes for everyone else......but I feel as though winning over Howard is like winning over Simon Cowell
Old Nov 17, 2009 | 08:33 PM
rx7what's Avatar
Norcal RX7 Pimp
Pics?
Old Nov 18, 2009 | 04:30 PM
240slider's Avatar
X2 for pics.
Old Nov 19, 2009 | 05:44 AM
AtomicRex's Avatar
Sorry....our FTP server is down at the moment
I will update as soon as it is up and running again
Old Nov 19, 2009 | 06:20 AM
FCNAred's Avatar
what kind of heim joints will you be using? will it be possible to buy just the trailing arm and toe link?
Old Nov 19, 2009 | 08:56 AM
AtomicRex's Avatar
Woohoo....the pics are back
They are using spherical bearings.....I would sooner sell them as a complete kit, as I have had everything made up that way. And the majority of the cost is actually the bearings used for the trailing arm and toe links. You would only look to save approx £250 on the full kit price.
Old Nov 20, 2009 | 08:46 PM
M104-AMG's Avatar
drool . . .
Old Nov 29, 2009 | 10:39 PM
squalor's Avatar
How much tyre can fit with this ? Have you tried a 18X11 +45 rim ? What rim sizes have been tried so far ? Truly great looking work AtomicRex.
Old Nov 30, 2009 | 10:05 AM
AtomicRex's Avatar
We are running a 18 x 12J with a 13mm offset, and these fit.
Basically if your wheels fit on a standard car then they will fit with our arms
Old Dec 9, 2009 | 11:38 PM
4G63FD's Avatar
If I already have the lower trailing arms and toe links, can I just buy that arm with the pillow ball bushing in the middle from you?
Old Dec 20, 2009 | 04:32 PM
Sarusanj's Avatar
QM
Veteran: Navy
Veteran: Reserves
Same question. I just need the control arm.
Old Dec 22, 2009 | 11:00 PM
Monkman33's Avatar
Goodfalla Engine Complete
Dust boots?
Old Jan 5, 2010 | 01:16 PM
Rotary_Rocket!'s Avatar
x3 Already have M2 links, can I just integrate your control arm?
Fantastic product, keep up the great work.
Old Jan 6, 2010 | 08:26 AM
AtomicRex's Avatar
Ive had a look at this, and I dont think I can sell just the lower arm as the trailing arm is matched to fit with our arm, and I think the other aftermarket ones might foul them. I will however split the toe links out of the equation if that interests people??
Old Apr 27, 2010 | 08:42 PM
blackey's Avatar
I'd like to know what bearings are included. AKA metric or american, etc... AKA if AtomicRex was not around can I replace them.
Current pricing?
Old May 11, 2010 | 02:13 AM
Jay7 Nyc's Avatar
You still doing these? Havent seen much action from you..
Old May 11, 2010 | 02:28 AM
Jay7 Nyc's Avatar
What is the difference between the 2 bearing upgrades? Im in but am I the only one? =/
Old May 16, 2010 | 07:49 PM
Scrub's Avatar
bow leggin'
Originally Posted by monkman33
dust boots?
+1
Old Aug 17, 2010 | 01:47 PM
Islander's Avatar
I want to be in also! I'm actually ordering the RP toe links and trailing arms when i seen these. Do you still have these ready to go.
Old Aug 17, 2010 | 02:14 PM
AtomicRex's Avatar
I can supply these to you away from the group buy if you want?
There doesnt need to be one!
Drop me an email with what you want, and I will sort out everything on that with you
Old Aug 17, 2010 | 02:34 PM
Force13B's Avatar
No more G6
I wish the price was in USD and not GBP then i could afford them Absolutely stunning work.
