AST Removal
Old Apr 13, 2009 | 04:40 PM
FD3S-K's Avatar
Geby
AST Removal
So basically, what I've done is remove the stock rad cap and base, and put on a FC's cap and base, plugged the nipple on the water neck, and plugged the nipple on the bottom of the rad. Then from the FC's base I rad a 3/8th hose to the over flow tank.
Sounds good?
Old Apr 13, 2009 | 04:49 PM
Sgtblue's Avatar
Urban Combat Vet
Sounds good.
FWIW, I dremeled off the filler neck nipple then drilled and tapped the hole for an NPT plug. Looks a little better and IMO, less likely to leak.
Old Apr 13, 2009 | 10:02 PM
jkep21's Avatar
Just make sure you have no air in it. You can rent the funnel kit from autozone for free to make sure it's all out...
Old Apr 14, 2009 | 12:57 PM
FD3S-K's Avatar
Geby
Thanks guys.
Old Apr 14, 2009 | 04:52 PM
wickedywick's Avatar
love the mod, no problems with mine. And just like everyone else said, setup looks good.
Old May 1, 2009 | 10:15 AM
rescueranger's Avatar
do you have pictures? i'm planning on going this route, did you use rubber plugs?
Old May 1, 2009 | 12:37 PM
KaiFD3S's Avatar
SINFUL7
What I did is instead of plugging those 2 holes I just run the hose from the radiator to the nipple on the housing, I did this so that way if there is any air in the radiator it still has a way out.
Old Nov 21, 2009 | 10:14 AM
str8ryd's Avatar
Nearing Completion...
Old thread bump .
I did the same thing as you Kai. Just wondering if this is a proper solution to the air issue?
Old Nov 21, 2009 | 11:48 AM
Sgtblue's Avatar
Urban Combat Vet
Originally Posted by str8ryd
Old thread bump .
The hose leading from the housing goes to the bottom of the radiator, not really where you're likely to find trapped air. And granted it's not very big, but wouldn't it also present a by-pass to the radiator....allowing coolant to (essentially) return right back into the motor?
Old Nov 21, 2009 | 12:54 PM
Six Rotors's Avatar
I have just done mine.I also retained the hose from the bottom of the radiator to the t-stat housing.I fabricated a piece of SS pipe basically to replace the ast and fitted a plug with a 0.089in hole(yes I measured the size of the hole in the ast).I will post apic later.
Old Nov 21, 2009 | 02:25 PM
KaiFD3S's Avatar
SINFUL7
Old thread bump .
Not sure if it is the proper solution but I have been running it this way for the last six years and the engine is still running strong, even with the single...
Old Nov 21, 2009 | 07:47 PM
Six Rotors's Avatar
ast replacement pics
Here's what I did.Works just fine.
Attached Thumbnails AST Removal-ast-replacement-1.jpg   AST Removal-ast-replacement2.jpg
Old Jul 11, 2011 | 08:57 PM
orange7's Avatar
where did you get that pipe?
Steelwheelz
Sep 15, 2015 03:22 PM
