FC35RT4 Kit pics inside.
Old Nov 1, 2005 | 04:42 PM
Zero R's Avatar
Just in time to die
Here are some pics of the FC kit for the 35RT4. Well at least the manifold and a pic during mockup but it gives you the idea. Let me know if you have any questions.
Attached Thumbnails FC35RT4 Kit pics inside.-fc35rt4.jpg   FC35RT4 Kit pics inside.-fc35rt4-1.jpg   FC35RT4 Kit pics inside.-fc35rt4-2.jpg   FC35RT4 Kit pics inside.-fc35rt4-3.jpg
Old Nov 3, 2005 | 11:08 AM
88GT's Avatar
Thanks! The runners look equally good but appear to have ripples in them. Was this a first run manifold?
Old Nov 3, 2005 | 12:29 PM
Zero R's Avatar
Just in time to die
There isn't any ripples, it is a tapered manifold I think what your seeing is the coating.
-S-
Old Nov 3, 2005 | 12:45 PM
FC3S.USD's Avatar
Where is my Life ?
Looks very nice, This would me my # 1 choice . When I upgrade the to4e .
Old Nov 3, 2005 | 12:48 PM
88GT's Avatar
-S-
I thought so but had to ask. I'm sure the lighting is playing with it. A BIG thanks again!
Old Nov 4, 2005 | 03:37 AM
TooMuch4You's Avatar
how much are you guys selling just the manifold for?
Old Nov 4, 2005 | 06:20 AM
Turbo23's Avatar
Panda Bear
I am also intrested in the manifold, how much
Old Nov 4, 2005 | 12:25 PM
Zero R's Avatar
Just in time to die
I'm not quite sure if or how I want to sell manifolds yet. They wont be cheap as some others because I'm not mass producing them. Each one would be made after the order is placed. But I will stand behind them as long as you own them.
Old Nov 16, 2005 | 10:21 AM
BoostedRex's Avatar
NorCal 7's Co-founder
The FC kit looks great Sean. Should we expect to see the same type of boost response as the FD's who currently run this turbo? I just wasn't sure what the differences in the manifolds were between this one and the FD manifold. Thanks in advance for the info.
Zach
Old Nov 16, 2005 | 01:23 PM
Zero R's Avatar
Just in time to die
These are slightly shorter in length, response should be very similar.
Old Nov 18, 2005 | 02:02 PM
BoostedRex's Avatar
Hey Sean, are these manifolds SS as well? I was just wondering because the color of them looks odd to me. Unless they are coated with something.
Zach
Old Nov 18, 2005 | 07:59 PM
Zero R's Avatar
Just in time to die
Yes stainless, the black one your looking at is ceramic coated.
Old Nov 21, 2005 | 08:06 PM
mazdarick's Avatar
LS1 Here I come.
I got MINE!!!
Just wanted to let everyone know that I just received either the first, or one of the first of these kits for the FC. It's sweet. I waited a while, but hey, FC Guys, It's worth it.
Old Nov 21, 2005 | 08:47 PM
Johny zoom's Avatar
Whats the cost of this and whats included? Wastegate?
Old Nov 22, 2005 | 07:59 AM
mazdarick's Avatar
LS1 Here I come.
Mine came with a downpipe, kindof, it needs some modification because I have an aftermarked exhaust and need to weld my own flange on. Included a Tial 44mm wastegate vented to atmosphere, the manifold and assorted fittings for oil and water cooling. The only thing that wasn't included to hook it all up was a 12mm x 1.5 to -4 an adapter to install in the front engine plate. This is where the included -4AN ine will attach. I just ordered that fitting from Summit racing. I'll let you know for sure if it fits once it comes in. Also all connections for turbo, wastegate and DP are V-band which makes installation pretty easy.
--Rick
Old Nov 22, 2005 | 08:20 AM
ultradef's Avatar
Ready to Rock
Sean, can you give us any info on pricing? Please PM me if you don't want to post it here. Thanks.
Old Nov 22, 2005 | 10:30 AM
Zero R's Avatar
Just in time to die
Pricing is listed in the GT35R thread, I will list it here sorry.
Old Nov 22, 2005 | 10:34 AM
Zero R's Avatar
Just in time to die
Everything is included for hookup. you get manifold, DP,44mm gate, lines,fittings etc.
Rick, unfortunately got stuck being number one.So time sucked and block to feed fitting is included as well.
-S-
Old Nov 29, 2005 | 05:00 PM
BoostedRex's Avatar
MazdaRick,
Have you had a chance to get your car tuned yet? How soon are you seeing full boost? Also, what are the specs on the turbo you have? I wasn't sure if you got the RS wheel or what size A/R you are using on your turbine housing. Thanks in advance.
Zach
Old Apr 5, 2007 | 02:28 AM
dean23's Avatar
pwned
what kind of numbers can be expected from this kit?
ill be running a microtech on an SP 90 TII engine if it helps any
Old Apr 5, 2007 | 09:32 AM
Zero R's Avatar
Just in time to die
A lot of that depends on parts and tune. I have guys getting anywhere from 410-460whp on pump gas. You may do better or worse
-S-
Old Jul 18, 2012 | 12:03 PM
sharingan 19's Avatar
Rotary Revolutionary
So, I recently purchased one of your manifolds and was told it was for an FC. Looking at these pics it looks like its actually for an FD. Is there any hope of making it work?
Old Jul 18, 2012 | 01:08 PM
R-X-R's Avatar
how much does the kit run for?
12mm, 15, 4, an
