Look at these Dyno Numbers!!!!
Old Jan 26, 2003 | 10:54 PM
pianoprodigy's Avatar
Missin' my FD
These are from Atkins' Site. I'm looking at getting the Camden S/C. Check out the numbers they posted! Are these flywheel? They have to be right. 275 at the wheels at 9 psi! That would be like 325 fwhp! Any input here guys. http://www.atkinsrotary.com/dyno.htm
Old Jan 26, 2003 | 11:04 PM
Manolis_D's Avatar
Most likely at the flywheel.
Keep in mind that's all carbureted stuff... Might be a bit tricky to get something like that on there with fuel injection (aftermarket ECU a la Haltech, Electromotive, tec.)...
Looks like fun
Manolis
Old Jan 27, 2003 | 04:48 PM
Missin' my FD
Any More Input Guys
I know you all hate S/Cs but just humor me and respond.
Old Jan 27, 2003 | 04:58 PM
HeffBoost's Avatar
Keep Right Except to Pass
I'd have to know a lot more about the specifics of each setup to give you an educated answer. I thought about 6 pounds was all you could run on an n/a(6-port).
Those #s have to be at the flywheel.
You'll get more HP easier and cheaper with a 13BT.
Old Jan 27, 2003 | 06:53 PM
CrazyDude's Avatar
Don't get a turbo motor. Turbochargers are proven to cause testicular cancer.
Get the supercharger and a big carb. The bigger your streetport, the better. And get a cat back (borla or RB). And a light flywheel.
Are you passing emissions now? It would not be terribly difficult to pull all the SC off and put all your old **** on to pass emissions. This is all on advice from a VERY reputable source (head buy at MazdaTrix... he does, after all, run a 9.83 quarter mile with a supercharged 3 rotor...).
Give them a call. See if you can talk to Dave, I think he is the head hauncho responsible for the SC setup.
And remember, turbo's cause cancer. really.
Old Jan 27, 2003 | 10:32 PM
Missin' my FD
Any more input?
These comments are somewhat helpful. Has anyone seen a successful 13B Carb S/C setup.
Old Jan 27, 2003 | 10:47 PM
Liquid Anarchy's Avatar
We come with the Hardcore
Oh yes... swapping an FB front cover, a different intake manifold, a different fuel pump, fuel pressure regulator, and running premix is a LOT more difficult than a full 13BT swap...
Old Jan 27, 2003 | 10:53 PM
BlackRx7's Avatar
Daily Domestic Killer
you crazy, I've never hear of turbos causeing cancer, how, but the high pitched squell? Well if they I do I can think of ten other things that do and come in contact daily, just remeber EAT YOUR GREENS!!!
Old Jan 27, 2003 | 11:13 PM
HeffBoost's Avatar
If this was sarcasm then please explain yourself.
The guy was asking for opinions and that was mine.
Granted I've seen worse, but it's these type of comments that give this forum a bad name.
Way to look a gift horse in the mouth. Sorry but I'm torqued now.
Old Jan 28, 2003 | 01:39 AM
CrazyDude's Avatar
Ask the fellas at Mazdatrix about their Carbed SC setup; they abandonded an expensive FI system for a large carburetor.
Also, I just noticed that Camden Superchargers now has a new homepage, which they have this point in the Q&A section:
"11. Can I go with either a fuel injection setup or a naturally aspirated setup?
-You can do either setup, we also supply the kit to go from naturally aspirated to fuel injected here."
No doubt it will be quite expensive, but you should ask them about it anyway, or wait for them to put more info up on the website. They also say you can get more boost with a larger pulley, so you should inquire about what is the max speed you can run one of their blowers at (i.e. determine max boost).
I beleive the manifold they give you for a 6 port engine runs into the 6ports as well, so it'd probably be worth making one of those sleeves that ramps the air into the chamber (cause it'll alwasy be open). If you have your motor apart, there is a really good way to do this using a steel-putty-epoxy stuff.
I suppose if you are a REAL badass and want to drill a couple holes into your shiny new intake manifold, you might be able to work in electronic 6port activation.
There are a few things to consider, of course, if you want to go to a carb'ed setup. The ECU will not like to run without a TPS or OMP hooked up, so I think you need a distributor of sorts.
Old Jan 28, 2003 | 02:20 AM
HALO's Avatar
I have a friend that has been in contact with them several times. He has been planning on ordering a built engine and super charger. He isn't gonna be satisfired unless he has over 400 RWHP.
They said they can do that but it is gonna cost. And of course he will pay the price. He would sale his mother if he had too.
I, of course, have been trying to talk him in to getting the built engine and going with a custom turbo system. Compare 70% effeciency with a properly speced turbo than 50% with superchargers.
Rotate86
May 18, 2018 02:44 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
