Vacuum Diagrams(Stock, Simplified Sequential, Non-sequential, Single Turbo
Old Jun 19, 2008 | 12:54 AM
StreetRage's Avatar
Built not bought.
California..... But there is always the illegal way of passing emissions.... Is it worth doing the whole vacuum hose removal thing or is it not worth it and not needed?
Old Jun 19, 2008 | 02:29 AM
twomucboost4u's Avatar
Always Under Construction
Honestly if you plan on staying twins dont go non-seq. if you want simple save up and go single youll thank yourself down the line. If you would like to help the simplified seq. and make it a little easier to trouble shoot if you do have problems then you could do the simplified seq. system. Help reduce the amount of parts that could fail, makes the lines easier. It does remove all the emisions stuff and keeps all the solenoids for the seq. system to work properly.
Chris
Old Jun 25, 2008 | 08:54 PM
David0ff's Avatar
what do you insert in the lines where it says restrictor in this line .. i am confused about that
thx
Old Jun 25, 2008 | 08:56 PM
  #29
Mahjik's Avatar
Mr. Links
Arrow
thx
Restrictor pills (or carb jets):
http://www.autosportracetech.com/RX-7/faqs.htm#Pills
Old Sep 29, 2008 | 09:54 PM
  #30
_Bahrx7_'s Avatar
so on the simplified sequential diagram, what do i with with everything that says delete?
Old Nov 1, 2008 | 01:43 PM
  #31
Get block off plates and remove it.... You can buy them from banzai...
Chris
Old Nov 23, 2008 | 09:39 PM
  #32
taylor7787's Avatar
im looking to replace my vacuum lines, where would everyone suggest to buy a vacuum line kit from?
Old Apr 14, 2009 | 08:13 PM
  #33
Rotorsex's Avatar
BUMP
i was wondering with the diagram below, is that seriously all the hoses you need!?
if it is, i dont understand why everybody doesnt go single then?
Attached Thumbnails Vacuum Diagrams(Stock, Simplified Sequential, Non-sequential, Single Turbo-non-sequentialchrisversionboostcont.jpg
Old Apr 14, 2009 | 10:49 PM
  #34
arghx's Avatar
rotorhead
^ that is a nonsequential diagram, not a single turbo diagram.
If anything, the diagram could be simpler. I don't agree with keeping the fuel pressure regulator control solenoid valve. you can run the stock FPR right to a vacuum/boost source. that solenoid is mostly to prevent vapor lock, which simply doesn't happen.
as you can see, it only comes on when fuel temps are over 80 C (which rarely/never happens, ask someone who has hooked up their fuel temp sensor to their water temp sensor connector by accident). The car also has to be left in Neutral for the solenoid to engage. I know it says "except neutral" but if you have ever looked at computer logic diagrams (that is an AND gate), that little circle thing next to the D means there is an inverter there which essentially changes the signal. anyway the solenoid is useless because it never really turns on if you examine the logic circuit, that's all you need to know. just take it out.
the PCV valve is also unnecessary. the filler pipe vent can be routed to before the turbo inlet or to a vented catch can. a PCV valve only draws crankcase vapors out under low engine loads for emissions purposes. Under high load the vapors escape on their own without a PCV valve, and in fact under high load the PCV valve closes. I don't know why the charge relief valve is still there either. if you are premixing the two dark blue lines can go, they are for the OMP.
One thing people do that I don't agree with is removing the TB coolant hose and fast idle system. all that does is make the car idle like crap on cold start, just to save a small amount of plumbing and have a negligible decrease in intake temps.
Attached Thumbnails Vacuum Diagrams(Stock, Simplified Sequential, Non-sequential, Single Turbo-fpr_solenoid.jpg
Old Apr 30, 2009 | 02:13 PM
  #35
barnett87rx7's Avatar
lite rotary = easy push
Hi does anyone have these diagrams for the s4 FC engines?
Old Apr 30, 2009 | 04:26 PM
  #36
svre46's Avatar
Thanks for the awesome post. I had a quick question. When doing simplified sequential, Do you need any resistors for the solenoids that you remove such as the EGR? I remember reading that if you put resistors in between this will stop check engine codes from coming up, but wasn’t sure if this just applied to going non sequential or not. I just want to be sure.
Thanks
Steve
Old Jun 21, 2009 | 05:23 AM
  #37
cobaltfd3sracr's Avatar
your awsome im going to be needing this when i put my car back together
Old Aug 10, 2009 | 03:50 PM
  #38
1985GSL's Avatar
What is the purpose of the bright yellow line in the full non seq with aftermarket boost controller diagram?
Old Aug 10, 2009 | 10:46 PM
  #39
93vrfd_houston's Avatar
hey chris, thanks for posting this! i'll need it when i get to install those bnr's and rob baily's solenoids that i got from you! i know they were already in a sticky but it's nice to see them all together.
Old Nov 20, 2009 | 05:16 PM
  #40
riprx7's Avatar
Do do the simplifications do I have to buy alot of Vaccume connectors to rerouth the vaccum hoses like shown in the pic. And were do I get the vaccum conectors?
Old Jan 26, 2010 | 12:05 AM
  #41
Azriel_Strife's Avatar
Eff Dee Three Ess
Ok newb question, but whats the difference between the "charge relief valve" and the "blow off valve"
Old Jan 26, 2010 | 12:46 PM
  #42
jmadams74's Avatar
The CRV releases any airflow created by the secondary turbo while the primary turbo is operating (before the secondary turbo is called on to kick in -- around 4500 RPM).
The BOV releases pressure from the entire turbo system when you let off the throttle so as not to create a sudden (and over time harmful) backpressure against the turbos.
Old Jan 26, 2010 | 10:15 PM
  #43
Eff Dee Three Ess
So by all rights since I have my turbo's paralleled I can remove the CRV alltogether?
If that's the case, whats the best way of plugging that hole?
Old Feb 1, 2010 | 08:20 PM
  #44
Eff Dee Three Ess
I REALLY need an answer to the above question. Can I remove the CRV since I've gone parallel?
Old Feb 1, 2010 | 08:29 PM
  #45
Mahjik's Avatar
Mr. Links
Yes
Old Feb 1, 2010 | 08:33 PM
  #46
FDSeoul's Avatar
Corea FD
nice stuff
Old Feb 1, 2010 | 09:12 PM
  #47
Eiji's Avatar
Stock JDM 99+ Vacuum Diagram
FWIW the stock JDM 99+ vacuum diagram in colour...
Attached Thumbnails Vacuum Diagrams(Stock, Simplified Sequential, Non-sequential, Single Turbo-colours8diagramjaphires.jpg
Old Feb 1, 2010 | 09:21 PM
  #48
Prometheus's Avatar
Still got it.
Can someone please convert these to a vector image, so we can blow these things up huge and print them poster size???
PLEASE!!!???!!!???
Old Feb 1, 2010 | 10:00 PM
  #49
NissanConvert's Avatar
Please somebody help!!!
I recently took the nonsequential diagram to office depot. It doesn't need to be vectorized to enlarge up to poster size.
Old May 26, 2010 | 10:28 AM
  #50
Djgreeny's Avatar
Great thread...well done lads...Im about to undertake parallel conversion the my twins...Cheers.
