Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Unique Fabrication and Transplants
How to--- install a Drysump. (finally, I know)
Old Jun 28, 2008 | 01:02 PM
to_slow's Avatar
What do you think about returning the turbo line in this spot?
Some input will be great
Thanks
Old Jun 28, 2008 | 02:24 PM
GtoRx7's Avatar
Collections Hold
Thanks
That would not be a good idea, its a machined galley way to the second stage scavange pump. It must be mounted higher up to avoid dumping into the oil level inside the engine.
Old Jun 30, 2008 | 02:29 PM
auricomXL's Avatar
update,
i got my gilmers from tweakit last week. they look great by the way. i have not run them on the motor yet, but they look stong and well crafted. the only problem i had with them was that the water pump pulley's center bore was not quite large enough, so i had to hone it out a bit. i have no idea why that would be the one thing that wasn't perfect, but oh well.
i still am having trouble finding info on the rear regulator. does anyone know if this guy can be replaced with a bolt? i've got my external regulator, so that should be all i need right? if i block of my rear regulator i will just make a special plate with a SINGLE inlet line to place on the top of my oil filter surface (the filter itself is no longer mounted here). this plate will allow oil to flow into the block from where the outlet of the filter should be, but will block off where the filter inlet should be.
do i have the oil circuit right in assuming this will work? any input would be great!
Old Jul 1, 2008 | 04:52 PM
  #29
GtoRx7's Avatar
Collections Hold
Originally Posted by auricomXL
update,
You are correct when using a external regulator, the OEM spot in the rear can be blocked off. Thats all you need
Old Jul 28, 2008 | 02:30 PM
  #30
initial D is REAL!'s Avatar
awesome!!
bzebern
274
Apr 21, 2019 11:39 PM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
