Will these fit?
Old Mar 14, 2010 | 10:47 PM
acekid7's Avatar
Rotory United RU.
Will these fit?
Will these fit with out any modification or wheel adapter, and what tire size would look nice on a stock setup. I'm thinking a 205/50/15 on the back and 195/50/15 on the front. Its a gslse. Thanks guys.
http://www.discounttiredirect.com/di...w=7&vid=006202
Old Mar 14, 2010 | 11:11 PM
Jibaro 12A's Avatar
searching...
GSL-SE are 14"
Old Mar 14, 2010 | 11:16 PM
acekid7's Avatar
Rotory United RU.
Originally Posted by Jibaro 12A
GSL-SE are 14"
i know. Im saying my car is a stock setup no lowering springs or anything. How will that size tire look with the rims i have in the link.
Old Mar 14, 2010 | 11:25 PM
84stock's Avatar
link doesn't work...I run 205/40r17 all the way around on mine with racing beat springs. Tiny rub on the front with a full lock and tiny bump.
Old Mar 14, 2010 | 11:44 PM
acekid7's Avatar
Rotory United RU.
here is the proper link
http://www.discounttiredirect.com/di...ivan&tmn=DR-19
Old Mar 14, 2010 | 11:45 PM
jshiz's Avatar
Actin Like I'm Drunk
What's the offset?
Old Mar 15, 2010 | 12:12 AM
Sgt Fox's Avatar
Stigulus Moderatorai
From the manufacturer:
DR-19 (GLOSS BLACK, GUN METAL, CHROME, SILVER)
DR-19
SIZE:
15x7 / 16x7 / 17x7.5 / 18x7.5
BOLT PATTERN:
15" - (4 x 100/114.3)(5 x 100/114.3)
16" - (4 x 100/114.3)(5 x 100/110/112/114.3)
17" - (4 x 100/114.3)(5 x 100/110/112/114.3/120)
18" - (4 x 100/114.3)(5 x 100/110/112/114.3/120)
OFFSET:
15" - 40mm
16" - 40mm
17" - 42mm / 45mm
18" - 42mm / 45mm
WEIGHT:
15" - 15.60 lbs / 7.07 kg
16" - 18.20 lbs / 8.25 kg
17" - 20.00 lbs / 9.07 kg
18" - 21.00 lbs / 9.52 kg
LIP MEASUREMENT:
15" - 1.4"
16" - 1.4"
17" - 1.43"
18" - 1.43"
FINISH:
Gloss Black Machined Face, Gold, Gloss Black, Machined Face w/ Gloss Black Lip, Gun Metal, Silver, Chrome
Old Mar 15, 2010 | 12:19 AM
jshiz's Avatar
It should fit fine. It may rub under full lock like 84stock's
"edit"
If i would get a set of drag's it would be these. mmmmm 0 offset.
http://www.discounttiredirect.com/di...il.do?pc=48695
Old Mar 15, 2010 | 04:11 AM
ricerockettuner's Avatar
zoom zoom
is the offset different between a stock gs and a gsl se? i have a 82 and am looking to run 17s and have the same look as u 84stock. im gonna change my bolt pattern with wheel adapters and they call for a offset of +20. the wheels adapters are 15mm. so that means i should go with +35 offset right? for a 205-40 r17 and maybe a 225 on the back?
Old Mar 15, 2010 | 08:25 AM
acekid7's Avatar
Rotory United RU.
so this will work fine on the se. 15" - (4 x 100/114.3)(5 x 100/114.3)
Old Mar 15, 2010 | 09:32 AM
jshiz's Avatar
I believe the offset between the GSL-SE and the other models are different. I believe they covered that in the 1st gen fact thread. search around.
4x114.3 is what you'd want.
Old Mar 15, 2010 | 09:36 AM
acekid7's Avatar
Rotory United RU.
thank you. thank you new rims are on there way but now what tire should i get
Old Mar 15, 2010 | 11:42 AM
84stock's Avatar
don't cheap out on the tires, i did this once and regretted it. BFG traction ta's are pretty sweet along with a lot of the japanese stuff.
Old Mar 15, 2010 | 01:06 PM
broncoblitz's Avatar
For sizing on an SE I'd go with either 205/50/15 or 205/55/15 all around
205/55/15 is closer to the stock diameter on an SE
I'm running 205/55 on the front and 225/50 on the rear. I have a +32 offset so I'm sticking out 8mm more than you would, but I don't see inside clearance being an issue since the stock wheels are 205 and +40 offset.
Old Mar 15, 2010 | 03:42 PM
electric man's Avatar
gsl-se rims
i'm running a 205/50/16 all the way around on 16x7 rims with a +40 offset. i have about a quarter inch clearance on the stock front struts
Attached Thumbnails Will these fit?-img_0882.jpg   Will these fit?-img_0875.jpg
Old Mar 15, 2010 | 06:56 PM
84stock's Avatar
Looks great!!!
I was gonna go with 16" but I couldn't pass up the deal on my rims & tires. They were used for 3 months, then the owner put his winters on and the car got smashed. The whole set including tuner nuts were only $800 and the gold goes so well with the gold pearl in my paint.
next comes the wet sanding and pin striping...
Old Mar 16, 2010 | 09:45 AM
acekid7's Avatar
Rotory United RU.
thanks guys i guess ima go with a 205/55 or a 205/50 i just might go with the lower profile one but im not sure yet. maybe in the future i will get some lowering springs
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
