Torque converter removal.
Old Nov 14, 2009 | 10:39 PM
Crazyk82's Avatar
When in doubt...flatout
I need some advice on removing the torque converter from the flex plate. The auto transmission is already disconnected. Are their any special tools of anything cuz this is becoming a big pain.
Another thing is I can turn the motor over with not much effort via the flex plate. Could this indicate low compression?
Thanks in advance.
Old Nov 15, 2009 | 11:35 AM
wecycle's Avatar
Tq
Ideally you pull the TQ with the trans so you do not mess up anything.
You turn the engine to gain access to the bolts.
Old Nov 15, 2009 | 12:42 PM
dj55b's Avatar
if I recall correctly, there was like 4 or 6 bolts on the engine side of the torque converter. You can access them easily with a regular wrench. I had a buddy hold another wrench form the other side to make sure that it didn't spin as I was trying to take them out. Once the bolts are out though, all you do it slide it out. It might need a couple of taps to break it loose but it will slide out. Also just a hint, there will be some fluids left in there so don't pull so hard and spray yourself
Old Nov 15, 2009 | 02:23 PM
Crazyk82's Avatar
Ya haha. I got it out and flex plate off too. Trying to figure out the wiring for the manual now.
Old Nov 15, 2009 | 11:54 PM
dj55b's Avatar
wiring for the manual? Isn't just the reverse light switch? I don't recall of anything else besides that and the starter wiring, but thats the same.
Old Nov 16, 2009 | 02:01 AM
Crazyk82's Avatar
You have to bridge the neutral saftey switch which ive done now i just have to connect up the revers lights
Turblown
Vendor Classifieds
12
Oct 17, 2020 03:25 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
