Detailing and Restoration For information on detailing or restoring your rotary look here.
OK to clay bar after final rinse at Pay n' Spray?
Old May 25, 2012 | 04:50 PM
Oun's Avatar
Oun
I can confirm.
After washing the car at the coin-op station and while the car is still wet after using the final rinse, do you guys think it should still be ok to use the clay bar before hand waxing? instructions say to use the detailing spray which is $8 vs entire car wash $6 (soap, foaming brush, rinse, final rinse). The detailer is used for "lube" but can't the filtered final rinse water be used for the same purpose?
thank you for your time.
Old May 25, 2012 | 05:20 PM
RCCAZ 1's Avatar
Not likely. Dries too fast IMO, plus the detail spray lubricates much better than water. Just spend the $8 and save yourself some frustration.
Old May 29, 2012 | 07:08 PM
Rob XX 7's Avatar
FC guy
Since clay was invented i have always used soapy water after the car was washed. Works ten times faster then dicking with sprays.
You want even faster and better use elastofoam block
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
jim_chung
1st Gen General Discussion
6
Aug 27, 2015 11:42 AM
