Vibration/shuddering/clank! sound diagnosing please!
Old Dec 2, 2001 | 06:23 PM
Tron's Avatar
I have an 86 GXL. New centerforce clutch was installed 20k ago. I have had the car in storage for about 3 years. I drove it over the weekend and noticed some vibes and shimmying at low speeds. Also when going from 1st to reverse there was a metallic clanking sound.
I have searched all the threads and am coming to the conclusion it is the U Joint for the DriveShaft...What do you guys think?
Thanks!
Old Dec 2, 2001 | 10:04 PM
Tron's Avatar
I forgot to mention I also hear a squeaking sound when the vehicle is slowly moving...
Anyone?
Old Dec 2, 2001 | 10:47 PM
Xentrix's Avatar
Kill Bear
check your wheel bearings, grab the rim while attached and shake it fairly hard, if you feel a pop, it will be the bearings.
Old Dec 3, 2001 | 11:54 AM
Tron's Avatar
I know it's not the wheel bearings, I just check them as stated above.
The thing that tips me off is the pop/metallic clank when going from forward to reverse...
Are they second gen driveshafts rebuildable? Or do I need to order a new one from Mazdatrix?
Old Dec 3, 2001 | 06:12 PM
Tron's Avatar
Please help me.
Well I just crawled under my RX7 and reefed on the driveshaft a few times and the halfshafts a few times. There was not a large amount of play, in fact there was not any play at all in the halfshafts or driveshaft.
Now I'm stumped...I thought that if the U joint was bad there would be some play in it.
The squeaking sound seems to be based on rotation, as it is time specific - I mean that the time interval between the squeaks is the same if the vehicle speed is the same...Uggh..
Would I hear the squeak with the clutch in if it was the throw out bearing that was bad?
Brett
Old Dec 3, 2001 | 06:21 PM
HAILERS's Avatar
HAILERS
I vote u-joint. Take the driveshaft out and inspect it in your hand. Mazdatrix driveshafts work good. Get the non oem. They as you know have the replaceable u-joints. Or take that one you have, if indeed bad, and go to a local shop and they will make you a driveshaft with replaceable joints out of your old one. Then again it could be another thing all together.
Old Dec 3, 2001 | 08:35 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
You were probably right the first time (driveshaft) that's a common failure. I suggest the Mazdatrix rebuildable ones.
Brad
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
