Top Speed for 2G RX7 TurboII?
My '89 T2 has been up to 163mph. Of course that was on a top speed dyno run. It could go higher with the gearing from the factory, but the operator had me shut it down. Amazing how fast you can go without drag.
jerk_racer@hotmail.com
Thanks for the info and input... I take it there is no official number given out by Mazda for it? That would make sense as I haven't seen anything... Well, who wants to post their top speeds (who has the fastest 2g rex here, anyways?)?
Actually there is an "official" top speed from Mazda for the TII, and its 235kph "real" (something like 255kph on the speedo). I've had mine up to 230kph, and I could feel that I had at least 20kph more to gain...if I had more room
And thats pure stock. With minor mods (DP, catback, filter, TID mod) you should very well be above the 270kph
Thats "supercar" territory babeeeeee.....
Trending Topics
I knew there should be some official spec for top speed, but I was beginning to not think so. I wonder why its hard to come by (or maybe i'm just looking in the wrong places... i've searched the net, and checked in the 2 RX7 books i just picked up: nothing).
Keep the responses coming... I wanna see how fast you and your cars have gone.
i hit 140+
ran it up to 140mph on flat road, then came the slight downgrade where i hit 142-3, then backed off for safety reasons. road got rough. This was with a passenger, too.
You can use this formula to figure out the gearing-limited speed. Of course, it doesn't take into account drag/weight-limited speed, ECU-limited speed, traction, road grade, wind, etc., but it's a good reference anyway.
mph = ((rear tire circumference in inches) * (Engine RPM)) / ((Transmission gear ratio) * (Rear end gear ratio) * 1056)
Here's an example for a stock 88 TII given:
205/55R16 Tires (78 inch circumference)
7000 Engine RPM
0.762 5th Gear Ratio
4.10 Rear End Gear Ratio
mph = (78 * 7000) / (0.762 * 4.10 * 1056)
mph = 546000 / 3299
mph = 166
7000 Engine RPM
mph = 546000 / 3299
mph = 166
Originally posted by photoresistor
Hey, Evil Aviator, How fast does that 20B monster of yours go??
Assuming that the current 88 NA tranny will hold together longer than the initial tuning session (which it probably won't), the car would have a top end of 181mph with the 4.10 rear, or 190mph with the 3.909 rear. I am currently shopping for a good dogring transmission, and maybe a better rear end, with a top speed goal of 240mph. No, it's not a drag car. Yes, it's street legal in Florida.
Originally posted by Evil Aviator
Hehehe, well I'm still waiting on some EMS components, so right now I figure that I could push it at about 2mph.
Oh, I didn't know it was still being worked on.
Stage 1 - Get the freakin' thing running! (almost there-just need IC plumbing and some EMS/Ignition parts)
Stage 2 - Be able to drive it harder than Grandma would (need new tranny, driveshaft hoop, scattershield, and fire extinguishing system)
Stage 3 - Kick butt (need MUCH wider tires and therefore a wide body kit, aerodynamics, and other go-fast stuff)
Oh, if I had the money....
[/B]
[/B]
Oh, and no, you can't win, because every time that I work extra to make more money, I don't have any time to work on the car.
Originally posted by Sebring7
go for the hks dogmission!
Road and Track has done a few comparisons over the years, there are two books that have several articles with top speeds listed: Road&Track's Guide to the All New Mazda RX-7, it lists 128mph right on the back cover-- consistant with other printed articles I have. The other is a compilation of articles also with some from England, etc., Mazda RX-7 Gold Portfolio (ISBN 1-85520-333-2).
I didn't find any references to top speed in any of the US brochures I have (all from 1979-1993), but in the other two guides I've seen T2's listed at 140-144, depending on the article and NA's listed about 125-128.
Greg O.
Greg O.
Azevedo
26
Mar 1, 2019 09:19 PM
82streetracer
Aug 23, 2015 09:28 AM
rx8volks
Canadian Forum
Aug 13, 2015 04:55 AM
