Black/Grey/White smoke... Fuel smell...Help?
Ok guys here's a vid and unless I'm going blind it seems the FD is blowing out a ton of white/grey smoke. Can anyone confirm from the video?
http://s50.photobucket.com/albums/f3...t=MVI_0284.flv
ThanX
ThanX
Well there are two colors to watch out for white= burning coolant and blue=burning oil... Does it do it all the time? and did if just start? Or does it just do it at first start up? It might be a blown coolant seal hense the white and since it just started its breaking up some carbon inside the motor hense the grey tint... If you would like to confirm its a coolant seal you can drain the whole system of the coolant and run just water... If the white goes away its coolant seal... Why you ask? Coolant burns white water has no color...
Chris
Chris
What does the smoke smell like? Burning coolant has a very distinct smell, smells kinda sweet. As for the color:
White: Burning water/coolant (or ATF)
Blue: Burning Oil
Black: Running Rich
The smell is probably a good way to tell what it is.
Blue: Burning Oil
Black: Running Rich
I have exactly the same problem as you.
This winter I had my twin turbo's (profesionally) rebuild, everything worked fine before, but, after the turbo rebuild my car smokes all the time just like yours, sometimes it smokes more than yours.
My engine was profesionally rebuild in 2007 and if a water seal is broken then I am going mad!
rgordon1979
40
Mar 15, 2022 12:04 PM
Adaptronic Cranking fuel table messed up?
sherff
Adaptronic Engine Mgmt - AUS
Sep 12, 2015 12:22 PM
