Rough shifting solution
Old Jan 8, 2008 | 12:23 AM
Ernesto13B's Avatar
Last year sometime I was having problems shifting into 3rd gear and sometimes 4th gear in my FD. If I tried to shift at 6k into any gear it would grind, and I thought the tranny was done.
BUT when I flushed the fluid out with Amsoils, 75w90 severe gear, I dont think Ive ever had a problem shiftiing into any gear since. It even shifts at high rpm, very smooth almost like a new car. For anyone whos tranny grinds, try this stuff, it works!
Old Jan 8, 2008 | 03:58 AM
nathan_s's Avatar
Bumble Bee Tuna !!
Thanks for the tip. I need to get my tranny flushed and so I appreciate the suggestion. I think I'll go with that.
Old Jan 8, 2008 | 07:01 AM
kwerks's Avatar
Racing Spirit
I had a similar issue last year where the shifts harder to do and the tranny would heat up a lot...
I went with mobile 1 synthetic truck tranny oil and its so smooth now and no heat. My friend also had this issue but he used GM syncromesh to solve the problem.
Old Jan 8, 2008 | 09:04 AM
DaleClark's Avatar
RX-7 Bad Ass
Most any good synthetic gear lube will do wonders for a gear box. I've seen trannies go from "this sucker is going out" to "good to go" with a simple gear oil change.
Dale
Old Jan 8, 2008 | 09:36 AM
Mahjik's Avatar
Mr. Links
Dale
Yep. Most of the time it has nothing to do with the brand of fluid, just that it's *new*.
Old Jan 8, 2008 | 08:49 PM
Str8Down's Avatar
Avoid Fuego Racing
Anyone try synchromesh? I have heard this stuff is like a tranny rebuild in a can.
Old Jan 8, 2008 | 11:22 PM
BigWillieStyles's Avatar
my second is a bit crunchy sometimes, will it help with the lower gears as well
Old Jan 8, 2008 | 11:29 PM
JConn2299's Avatar
reliable performance
Dale
So, if you've got a synthetic, like say Redline, in your gearbox how often do you recommend it be changed?
Old Jan 9, 2008 | 12:05 AM
silentblu's Avatar
anyone tried lucas?
Old Jan 9, 2008 | 12:41 AM
turboIIrotary's Avatar
i heard neo 75w-90 was very good
Old Jan 9, 2008 | 01:43 AM
FD3S2005's Avatar
SideWayZ The Only Way
isnt it about 60k miles it should be changed, also with the diff
Old Jan 9, 2008 | 05:20 AM
4CN A1R's Avatar
sleeper
dito, i am having problems with 3rd at redline
where should i go about buying some good synthetic syncro oil??
Old Jan 9, 2008 | 06:37 AM
nathan_s's Avatar
Bumble Bee Tuna !!
Uhm look at the 3rd post on this thread..... Its right there. Kwerks buddy used it.........
Old Jan 9, 2008 | 06:39 AM
4CN A1R's Avatar
sleeper
wouldnt really call that a flame there skippy
Old Jan 9, 2008 | 06:41 AM
nathan_s's Avatar
Bumble Bee Tuna !!
I put it on there just cause I wanted to put a smiley on there... I dont rally consider it a flame either. Just thought it looked cool.
Old Jan 9, 2008 | 07:32 AM
DaveW's Avatar
Racecar - Formula 2000
For preventive maintenance, and because 2nd was a bit notchy when cold, I drained the OE tranny lube and put in Valvoline 75W90 synthetic gear lube. That actually made the notchy 1st slightly worse. I then put in the NEO 75W90 gear lube, and that fixed the problem.
So, that proves to me that all 75W90 gear lubes may not have the same properties (friction modifiers, viscosity, etc.)
Old Jan 9, 2008 | 08:42 AM
kwerks's Avatar
Racing Spirit
Here is what I use and it solved my rough shifts
Mobil 1 Synthetic Gear Lube
LS 75W-140
http://www.mobiloil.com/USA-English/...75W-140LS.aspx
http://www.mobil.com/USA-English/Lub...LS_75W-140.asp
Old Jan 15, 2008 | 04:39 AM
4CN A1R's Avatar
sleeper
bumping this thread cause i am curious as to where i should go about buying some good synthetic (syncro) tranny oil??
Old Jan 15, 2008 | 06:50 AM
telum01's Avatar
Summit Racing has Royal Purple, great service and quick shipping
Old Jan 15, 2008 | 08:12 AM
GARCO MOTORWORKS's Avatar
I use Amsoil and no problems plus the Garfinkle ETB . I tried Lucas for a few months and did not like it ,back to Amsoil .Some one gave me the Lucas and they tried it as well and they removed it also .
Old Jan 15, 2008 | 08:36 AM
I use the Amsoil synthetic 75w90 in all customer cars with success, Gotham uses the same stuff
Old Jan 15, 2008 | 09:50 AM
Chadwick's Avatar
Mr Sparkles
Another Amsoil synthetic 75w90 user here. Have tried Neo, Redline, and GM syncro mesh. Amsoil gives me the best feel of the ones I have tried.
Old Jan 15, 2008 | 10:48 AM
kwerks's Avatar
Racing Spirit
Has anyone used
http://www.idemitsu-usa.com/default.asp?msg=wso&lwd=1
for their engine oil?
I'm on mobile 1 synth now...wondering if its worth switching over...
Old Jan 15, 2008 | 11:17 AM
dgeesaman's Avatar
My recommendation is Amsoil MTG GL-4 oil or Redline MT-90. You can get the Amsoil from any Amsoil rep. Redline is on some store shelves.
I recommend these because the friction coefficient maximizes synchronizer response. I would not use them in the diff though - something like an Amsoil Severe Gear or Redline Shockproof is best for the diff.
IMHO, if you're going to go to the trouble and cost of putting in synthetic gear lubes then it makes no sense to put the same thing in both the diff and tranny. The diff and tranny have much different lubrcation needs, and for not much extra cost you can put the best in both.
Dave
Old Jan 15, 2008 | 11:18 AM
dgeesaman's Avatar
Has anyone used
This thread is about gear oil, not engine oil
