$90 Dollar Custom Oil Cooler Lines (eBay)
Old Sep 29, 2016 | 07:53 AM
FührerTüner's Avatar
Penis Healthy
Originally Posted by JSmall
These guys make some nice fittings at a good price aye.. Just used them for my car
Vibrant Performance ::.
Not really cheap man...
Old Sep 29, 2016 | 10:15 AM
PinkRacer's Avatar
Licensed Zip Tie Mechanic
I used cheapie Ebay fittings direct from Hong Kong. lol A few of them were not great, but the majority were fine. Vibrant stuff is really nice, but a little spendy.
Old Nov 30, 2016 | 08:39 AM
Penis Healthy
Finally got the car running again. Just confirming these lines had no leaks at all. Max PSI at 60-70.
And Aaron, they werent made of copper.
Old Nov 30, 2016 | 09:02 PM
RotaryEvolution's Avatar
Sharp Claws
Originally Posted by Aaron Cake
Don't see what the issues is, so not sure why you are worried for your butthole.
Butt, just be careful with some of those eBay AN fittings. A friend had a bunch so I took a look at them. They were made of copper! But painted to look like the standard red/blue fittings. Which is odd, because copper is a lot more expensive than aluminium. This was discovered due to persistent leaks. And it was very soft copper, so it deformed once tightened down and was sealing not on the taper, but on the fact it squished into the male flare. Could only be used once because of this.
probably wasn't even copper, i've gotten some "aluminum" items from china that you could virtually dent with your fingernail and drilled through like a hot knife through butter.
but i have also used cheap AN fittings too, and sometimes you get a good deal. i've broken aeroquip, fragola, summit, earl's etc, etc, etc, so as long as they tighten once they did their job. AN fittings are not made for actual reusabilty, even though they may look flashy and as if that was their intent with the easy to disconnect flanges. i'm not a gorilla either, even 'quality' aluminum fittings just are soft and squishy and can't handle many reuses.
Old Dec 1, 2016 | 08:13 PM
ColinShark's Avatar
RX-7 Old Timer
Just a reminder, since the AN fittings are not idiot-proofed like the stock hardware:
1. Clean and lube the threads with engine oil
2. Tighten to just snug
3. Tighten one quarter turn. Done.
If you want to keep them looking nice, use an expensive aluminum AN wrench.
Old Mar 5, 2017 | 07:07 PM
Penis Healthy
Didnt like how this bottom an fitting was hanging so low. So I replaced it with a banjo.
Old Mar 30, 2017 | 03:04 PM
DankestKush's Avatar
I just picked up all of these parts, will post my results.
Although my total cost was $129.97, but i ordered 2-45 degree elbows, 2-90 degree elbows, 2 fittings, 6ft of hose, and the copper washers. I ordered the elbows from amazon, and the rest from ebay.
Old Jun 4, 2017 | 11:25 PM
fredrx7
20
Feb 4, 2017 10:57 PM
85TIIDEVIL
18
Sep 26, 2016 09:45 PM
ngirondo
Sep 3, 2016 11:01 AM
WondrousBread
Aug 30, 2016 10:55 PM
ngirondo
Aug 29, 2016 11:30 PM
