my new to me REPU
Old Dec 21, 2016 | 10:30 PM
Boriquaguerrero's Avatar
Retired First Sergeant
my new to me REPU
new to me REPU
Old Dec 22, 2016 | 10:49 AM
Jeff20B's Avatar
Lapping = Fapping
That's very nice! How stock will you leave the engine bay? I can tell you what you *could* do with it.
Hogged out Nikki on top of the REPU manifold.
modern nitrided Y or R5 irons
GSL-SE flywheel and a modern standard duty Exedy 225mm disc and pressure plate
DLIDFIS with an FB dizzy and BR8EQ-14 plugs
upgraded fuel pump and a high quality fpr set to 2.5psi for the hungry Nikki
RB road race header and a custom long primary exhaust
I wouldn't mention these mods if I hadn't done them myself.
Just don't fall into the trap almost all noobs to REPUs fall into these days by going EFI, or weber. Heck even the RB Holleys aren't all that great. Oh and if you must add boost, go turbo, not SC. Do an S4 on a custom tubular manifold like my next phase will be (hogged out boost prepped Nikki as well). It will spool fast and provide much more low end torque than big aftermarket turbos. The right rear tire should break loose, in gear, on dry road, going straight. Empty bed, of course. You can even fit an intercooler down in front of the oil cooler if more than 7 to 9 psi of boost is desired (but keep the charge pipes at 2" or no larger than 2.5").
Old Dec 22, 2016 | 11:54 AM
ROTARY_ADDICT-1's Avatar
VERY GOOD INFO YOU POST BRO I BEEN LEARNING A FEW THINGS HERE AND THERE FROM YOUR POST THANKS
Old Dec 22, 2016 | 12:01 PM
almoststockrepu's Avatar
This made me laugh.
Old Dec 22, 2016 | 05:17 PM
thanks for the info , im keeping it NA, i love the sound of a bridge port Carb
Old Dec 28, 2016 | 11:27 AM
Johnny Kommavongsa's Avatar
So what is the plans for this bad boy?
Old Dec 29, 2016 | 09:44 PM
as of right i just want to get it running once is running i will start doing more but my FD is a money burn pit lol
Old Jan 12, 2017 | 12:22 PM
Heeltoe914's Avatar
let me join in on the fun
Thanks for posting the tips of what to do in the engine bay.
Attached Thumbnails my new to me REPU-20170109_103929_001.jpg   my new to me REPU-20170109_103939.jpg
