just got my knight sports twins rf420
Old Oct 31, 2016 | 12:52 AM
MILOS7's Avatar
bought a set of used twins knight sports RF420,
Your thoughts?
shaft play within specs +-1mm
should I be concern with the slightly bend actuator?
pictures attached
Old Oct 31, 2016 | 02:07 AM
Are you sure they are used and not just hybrids build off used stock core turbos?
The exhaust wheels don't look like they have seen exhaust yet.
Or have they been re-rebuilt already?
Old Oct 31, 2016 | 02:20 AM
MILOS7's Avatar
They are used , not rebuilt to my knowledge . Removed from a fd due to single turbo conversion by the previous owner .
you can see the "knight sports" logo on the compressor housing...
Bought it from a guy who works at turbonetics,
they made a "centerpiece" of it as he said , He didn't know if they were rebuild or not .
I guess they cleaned the "turbos"... no clue.
Should I be worried about the bended actuator ?
it seems the compressor housing is missing the "dual nipples ", can I just reuse the one from my old twins?
Old Oct 31, 2016 | 04:57 AM
cib24's Avatar
Assuming you get them installed are you going to run them sequentially or non-sequential?
At say 1.0 bar (14.5 PSI), assuming the same car and modifications, what is the horsepower gain of the RF420s compared to stock twins running 1.0 bar (14.5 PSI)?
Is there a power gain across the entire RPM range? Are the RF420s laggier and by how much? Do the RF420s continue to make power beyond 6,000 RPM unlike the stock twins?
Old Oct 31, 2016 | 05:06 AM
MILOS7's Avatar
probably gonna keep them seq.
they are rated at 420 PS / 414 hp AT 1 BAR.
Detail here
Old Oct 31, 2016 | 05:15 AM
MILOS7's Avatar
the pre control actuator arm doesn't have the correct position to me...?
view or the pre control actuator arm , angled almost at 90 degres...?
arm on the bottom
and close view of the pre control actuator...
Old Oct 31, 2016 | 05:17 AM
billyboy's Avatar
The stock oem nipple piece coming from the primary compressor housing is a press fit - not threaded. Looks like Knightsport made their own piece there.
The "bend", are you referring to the top of the wastegate actuator, being pushed down slightly, hard to tell from the pic?? It might preload the spring a bit more...and keep the wastegate closed a tiny bit longer...I wouldn't worry, as long as the actuator is serviceable.
All the arm angles look good.
Old Oct 31, 2016 | 05:46 AM
MILOS7's Avatar
[QUOTE=billyboy;12119979]The stock oem nipple piece coming from the primary compressor housing is a press fit - not threaded. Looks like Knightsport made their own piece there.
I thought so , wonder were I could find the right part now...
Here is a better picture,
Since it is bended , I was wondering If I could just swap it with the one from my old twins.
Old Oct 31, 2016 | 06:11 AM
billyboy's Avatar
Looks to be stock with a coat of paint, so yeah, a straight swap should do the trick if you have concerns.
Old Oct 31, 2016 | 06:19 AM
MILOS7's Avatar
Thanks for the advises, my main concern now is where to find a dual nipple brass connector
like this one
Old Oct 31, 2016 | 10:46 AM
Can't tell from the pic if the threading they did where the dual nipple used to press in is tapered pipe thread or straight cut threads.
Because there is a reference cut at the top of the threads I would tend to think straight cut threads.
If that is the case you could use a dual banjo bolt to get two nipples.
If its tapered pipe thread you will probably have to do a nipple to a Y fitting or have something custom made.
Old Oct 31, 2016 | 02:59 PM
MILOS7's Avatar
here are better pictures, thanks
