Post Some Pics of your FC! :D <- Pics of your car go in this thread!!
Old 08-25-16, 03:05 PM
  #12476
infernosg's Avatar
Still not running and I suck at taking pictures.
Old 08-27-16, 04:00 AM
  #12477
ben.farnath's Avatar
That's some engine bay glory right there!
Old 08-28-16, 10:59 AM
  #12478
djSL's Avatar
Looks similar to mine Albeit much cleaner. I still need to tuck my wiring harness.
Infernosg: do you have any links for the stack's you're using? I've been trying to find ones that would accept those types of filters with no luck. I've been running open stacks for a year lol.
Old 08-28-16, 07:32 PM
  #12479
infernosg's Avatar
It's cleaner because I don't have any of the harnesses installed When it's all said and done it won't be much of a tuck.
I'm using the trumpets that came with the EFI Hardware Kit. I have their 55 mm throttle bodies and though I don't recall the length but their stuff can be found here: https://www.efihardware.com/ My air filters are custom K&N units based on one of their off-the-shelf offerings. I think I still have the original filter somewhere in the garage. My modification was to make them shorter so they didn't interfere with the oil filler neck otherwise they're as K&N designed them. I suggest checking out K&N's site. Don't limit yourself to car filters because I think mine were originally intended for a motorcycle application.
I like your setup though! I should have done what you did and utilized an existing carb manifold. What throttle bodies are you using? I went with 55 mm units based on the recommendation of Logan from Defined Autoworks since I have their port templates. The only way to get something that big was to use an IDA-style since all the DCOE-style units were 50 mm or less.
Old 08-29-16, 09:55 AM
  #12480
djSL's Avatar
Holy large picture! Sorry folks, I thought I resized that! :/
Lol. I plan on drilling a hole in the transmission tunnel so I can tuck my ECU harness and 02 sensor wires. I've already tucked the other side of the bay under the fender (I had to extend 40+wires, great fun). Since I haven't relocated my battery, I chose to leave the main power harness alone for now.
Thanks! I'm using a racehead.au 48mm throttle body kit. The stacks are 80mm at the opening and taper to 48mm. Since I'm stock port for now, I figured this would do. Eventually, I will PP or large street port. With long enough intake runners and stacks, I don't think flow will be too much of an issue. If it is, I'll just slap a turbo on and build a plenum or throttle body adapter for it.
As for the filters, I'm still on the fence. My stacks are spun aluminum so they are pretty flimsy and I don't feel comfortable clamping filters on them. I may pick up some Techno Toy Tuning 100mm length stacks and try to clamp some filters on.
Old 08-31-16, 10:27 AM
  #12481
Undercover
galaxy convoy's Avatar
Recent track day
And the vid
Old 08-31-16, 10:49 AM
  #12482
Gregory Casimir's Avatar
what suspension setup are you currently running^^
Old 08-31-16, 08:30 PM
  #12483
Undercover
Im using powered by max competition coilovers F 10kg R 8kg, rear camber arm, adjustable toe rods and the rear trailing arms camber link, the rest are stock(sway bars and bushing)
Old 09-03-16, 02:26 PM
  #12484
rotor_veux's Avatar
Originally Posted by Supreme_Origin
Can I ask what are your wheel specs? I'm liking this setup a lot..
18x10.5 +10 Front *225 40
18x11 +10 Rear *235 40
(Front spec) +35 From (D-max style front fenders) No spacers
(Rear spec) Rolled stock metal, I have lowered it and it will work out quite well with pretty much perfect tucked fitment on thick lips.
I had lowered it another 1/2 inch but, the parking lot tells you why I raised it back up for rubbing.
Current update
Completely scrapped out the bottoms of side skirts, nothing for support now
16x8+0 and 18x9+38
Old 09-09-16, 01:10 AM
  #12485
Area7's Avatar
cv cruiser, did you cut out the inner rear fender before you rolled it? or did you just hit it with a roller with the two layers of metal on the rear fender? the pull/roll in the rear fender looks perfect
Old 09-11-16, 07:15 PM
  #12486
SSS-TUTUTU
ILoveJDM's Avatar
Old 09-12-16, 11:38 AM
  #12487
vish86's Avatar
just ignore the dented fender lol
Old 09-12-16, 12:26 PM
  #12488
Forward, Always
R.O.D's Avatar
Found some oldies!!
That wing may be going back on onxe i square away the rest of the aero
Kinda miss the red..
Old 09-12-16, 12:35 PM
  #12489
Hurley990's Avatar
sunday wash session---
Old 09-12-16, 02:26 PM
  #12490
VeryFastDog's Avatar
Old 09-12-16, 05:25 PM
  #12491
Winter Rotary
Acesanugal's Avatar
Mine is the coupe. Kind of an older picture.. I pulled the dip off the wheels a while ago and it's got proper s4 aero mirrors now.
Attached Thumbnails Post Some Pics of your FC! :D &lt;- Pics of your car go in this thread!!-12963350_10154067546520960_220565517323681542_n.jpg
Old 09-18-16, 10:53 AM
  #12492
Rotarded
p0tat0s's Avatar
just finished wrapping mine aside from the bumpers. vinyl is arlon daytona blue metallic and the roof is some carbon fiber stuff i got from a friend
Post Some Pics of your FC! :D &lt;- Pics of your car go in this thread!!-ujw30ax.jpg
Post Some Pics of your FC! :D &lt;- Pics of your car go in this thread!!-e3itwfv.jpg
Post Some Pics of your FC! :D &lt;- Pics of your car go in this thread!!-yh1qam2.jpg
Old 09-18-16, 07:08 PM
  #12493
Akomix's Avatar
Went to the local park and grabbed some shots of the FC today! Here are a few of my favorites:
Old 09-24-16, 02:38 PM
  #12494
Murilli's Avatar
She's come a long way since the last time I posted a picture on here 4 years ago.
Old 09-24-16, 03:14 PM
  #12495
Akaviri's Avatar
Spotted a neat little Z-car today
At a local gathering
Old 09-26-16, 09:30 AM
  #12496
knoxgeeks's Avatar
Old 09-26-16, 09:31 AM
  #12497
knoxgeeks's Avatar
Just rolled 91,000 miles, much elbow grease and a slow and methodical parts hunt and she'll be cleaner and cleaner as time goes on. Anyone have a good source for touchup paint? Tornado Silver Metallic (K8) specifically.
Old 09-27-16, 01:08 PM
  #12498
reger's Avatar
Old 09-27-16, 10:38 PM
  #12499
blimp's Avatar
After a year without driving it. Back up and running.
Old 09-28-16, 01:16 PM
  #12500
SSS-TUTUTU
ILoveJDM's Avatar
Quick Reply: Post Some Pics of your FC! :D <- Pics of your car go in this thread!!
