RE-Furb.nl RX-4 project
Old Jan 7, 2013 | 04:17 AM
Furb's Avatar
Rotary and Engineering
Teaser...
More info soon...
Old Jan 7, 2013 | 08:38 AM
banzaitoyota's Avatar
What Subscription?
"like"
Old Jan 7, 2013 | 09:49 AM
CamanoRx2's Avatar
Intriqued..... Pics of the rest of the project, please....
Old Jan 8, 2013 | 01:10 AM
Furb's Avatar
Not much pics yet.. i've just started
Old Jan 8, 2013 | 04:43 AM
Pettersen's Avatar
This should be interesting
Old Jan 8, 2013 | 08:05 PM
CJarrett's Avatar
FC Racer
Subscribed
Old Jan 16, 2013 | 02:37 PM
CamanoRx2's Avatar
,,,,,,,,,,,, (That's the sound of impatient finger tapping) Help us out with some info....
Old Jan 23, 2013 | 02:43 PM
Furb's Avatar
Sorry for the delay mate
Had some serious setbacks, found out the body wasn't rocksolid like i thought..
The left siderail (dont know the exact English name) turned out completely rotted after prying away some underbody coating.
But that doesnt matter for the total project, it just affects the timeframe in which it wad all planned.
As for the engine, it will be built from my S5 TII engine that came out of the car i have owned for almost 8years. I was running it with a BNR stage4 turbo, pushing out somewhere around 400hp.
The engine was rebuilt over 10years ago and still running pretty strong with about 6bar compression
Defined Autoworks has calculated some port specs for me and will complete that with a matching header. They will be cutting custom porting templates for me.
primary ports--- Intake Open- 14 degrees ATDC / Intake Closed - 65 degrees ABDC
Secondary ports--- Intake Open 110 degrees BTDC/ Intake Closed- 65 degrees ABDC
Exhaust will be their race port configuration.
The intake will be a custom built heated inlet manifold that hold dual Weber 28/36DCD carbs.
Long small diameter primary runners for low-end torque, short large secondary runners for high-end hp
the primary and secondary are not connected to eachother, so the huge amount of overlal of the bridge will not affect idle quality and low-speed driveability.
Redline will be at 8500, because of the pretty basic build and everything is calculated to this spec. Higher redline is useless on a streetcar anyway
suspension will be a full gsl-se swap so it sits a little lower, have better brakes and a slip diff.
Also more choice in wheels with the different PCD.
Pics will come shortly, gathered a lot of parts over the last few months...
Old Apr 30, 2013 | 04:41 AM
Furb's Avatar
time for a long awaited updat...
i havent showed you guys much yet, but this is a summary of the last few months
i had a RA OMP adpater on my FC, but with the use of a different front cover it didnt fit anymore
also wanted to use the 4 port OMP of the S4 N/A, for premixing in the carbs and use the stock FC oil plugs on the housings.
so i built my own adapter to make it all fit
the FD alt used to sit on the side in my Fc but with the use of the 12A front cover it didnt fit anymore.
made a new one and flipped the alt for easier tensioning
with al the different gearing i will have, the speedo will be way off, so i needed to something about it.
also needed some new gauges and wanted them in stock location.
i replaced them all with a full Smith's Cobra series with programmable digital speedo
made some injector plugs
had to modify the FC shifter housing to make it to fit in the 4 chassis
plug for the speedo cable
Furb's Avatar
heavy duty throttle linkages
calculated and fabricated a throttle pulley
view of the engine with the engine bracket, alternator and 2stroke oil tank
time to remove the old
mounted the engine subframe
in with the new
shifter location is right on the money
this is where its at right now, lots more coming..
Old Apr 30, 2013 | 06:22 AM
Buggy's Avatar
I've Been Wankeled!
What are you planning on doing for a driveshaft? I want to do a 5 speed swap on my Rx-4 and I have a few spare TII transmissions laying around. Looks like a decent swap.
Old Apr 30, 2013 | 06:29 AM
Furb's Avatar
I will get a custom shaft
Old Apr 30, 2013 | 07:07 AM
John Huijben's Avatar
Looks good! I have to come and take a look when it's running!
Oh, do you know where to get the custom driveshaft yet? If your looking for a place to get it, there's a place nearby here that does great work with driveshafts, they also do dynamic balancing, they did my 4-rotor shaft too. Let me know if you need their adress.
Old Apr 30, 2013 | 12:56 PM
Furb's Avatar
Thanks mate, same when yours is done
Dont have a clue yet, got some other friends who have experience with companies who make custom shafts, but never hurts to have some more intell..
Old May 6, 2013 | 08:32 PM
CamanoRx2's Avatar
Amazing. Looks like you have an excellent pallet to work with. Love seeing this. If I could only get home to spend time on mine (or any of the other multiple projects I've got in work!)....
Thanks for the update!
Old May 10, 2013 | 11:21 AM
marquez1681's Avatar
cant wait to see it when its done
Old May 11, 2013 | 12:08 PM
engdahl's Avatar
Love seeing this
Old May 11, 2013 | 12:28 PM
RX2-Mazda-Fan's Avatar
Great progress! Keep up the good work!
Old Jan 8, 2014 | 03:55 AM
Furb's Avatar
before:
Old Jan 8, 2014 | 03:57 AM
Furb's Avatar
after:
Old Jan 8, 2014 | 03:59 AM
Furb's Avatar
just kidding.. not the same car
but the second one is the one i will be finishing instead of restoring my old one
Old Mar 20, 2014 | 06:29 AM
Furb's Avatar
been too busy with work , but finally got some work done!
started with the puzzle, so the painter could pick it up
work in progress
Old Mar 20, 2014 | 06:30 AM
Furb's Avatar
got hold of some awesome JDM goodness: SSR longchamps XR-4 wheels (for the RX-4, what's in a name )
front 15x7,5 ET5
rear 15x7,5 ET-7
rear wheels won't fit, but i have to modify the rear axle anyway, so i will be narrowing it 7mm on each side so it will fit perfect!
to be continued
Old Mar 20, 2014 | 09:07 PM
CamanoRx2's Avatar
Just know, that while you are 'struggling' to find time to make progress, there are tons of guys like me who aren't even at home to touch their projects. We are enjoying your posts, and wish we were the ones posting their own progress. Keep going. You are an inspiration to the rest of us.
Old Apr 8, 2014 | 05:34 AM
Furb's Avatar
yeah, i know... but for me progress is slow
i've had so much more time in the past to work on my cars, work is just taking it all up at the moment.
but there is more progress
scored some NOS centercaps in Japan for my wheels
got some small amount of spare time that i spent on my dash unit.
i had done this before, but since i have a LHD car now, i had to do it all over.
but this time even a better version, because i kept the stock circuitboard intact so it will make it a lot easier to connect it to the stock wiring loom later on!
