Miata Transmission Into NA FC-Results!
Old Apr 27, 2006 | 03:55 AM
  #101
too many 7's's Avatar
i have a 90' tII box in the garage but i am trying to shorten
my gear pattern cheapy as possable sence i am under 250 hp
i thought the miata gears would be ok i guess theres only one
way to find out
Old Apr 27, 2006 | 09:27 AM
  #102
RXgirl7's Avatar
IT LIVES!!
way to find out
id say go for it, unless you plan on drag racing, in which case the tall 1st gear wont help at all
Old Apr 27, 2006 | 11:25 AM
  #103
RETed's Avatar
way to find out
Bad idea.
The turbo FC trans runs wider / stronger gears.
They are not swappable.
Running a non-turbo FC (or Miata) transmission on an FC turbo is just plain stupid.
-Ted
Old Apr 27, 2006 | 12:47 PM
  #104
the tII box is just a spare i am using the 88' n/a box or the 90' n/a
box depending on witch one needs a rebuild more man i have too much
stuff in my garage
Old Apr 27, 2006 | 08:36 PM
  #105
torean's Avatar
vac leak
stuff in my garage
is the motor turboed?
Old Apr 28, 2006 | 02:16 AM
  #106
no ported n/a no dyno numbers yet so i don't know what it makes
i am expecting 190-225 to the wheels with all the time in this motor
it should have no problem getting there
Old May 29, 2006 | 02:16 AM
  #107
Pele's Avatar
Right near Malloy
Originally Posted by Pele
I
All the gear ratios ANYONE would ever need: http://members.ij.net/mrmazda/tranchrt.txt
Link invalid.
Updated:
http://mrmazda.no-ip.com/tranchrt.txt
Old Dec 15, 2008 | 06:46 AM
  #108
Pele's Avatar
Right near Malloy
Revisiting with an EPIC ANCIENT THREAD BUMP!
Just wanted to know how that transmission is holding up. There are claims in the 1st gen section that people have trashed the Miata tranny with stock ported 12A engines and minor bolt on mods.
Also:
LINK UPDATES
First, some links for anyone else interested:
5th gear interchange chart:
http://members.aol.com/solomiata/Mia...terchange.html - LINK INVALID, NO FURTHER INFORMATION
SoloMiata drivetrain interchange guide:
http://members.aol.com/solomiata/Drivetrain.html - LINK INVALID, NO FURTHER INFORMATION
Regearing Mazda transmissions:
http://www.angelfire.com/darkside/de...nsmission.html
Also mirrored here:
http://www.mazdatruckin.com/B2200/B2200.html
Miata VS RX-7 input shaft comparison:
http://myweb.cableone.net/currie/tom/RX7/trans.html
Further information here:
http://mazdatrix.com/faq/miatainputshaft.htm
If anyone has any archived info, please contribute.
I just got a 1999 Miata transmission the other day. It's stinking up the back of my SUV.
Old Dec 16, 2008 | 12:18 PM
  #109
RXgirl7's Avatar
IT LIVES!!
So far, the tranny has held up really well under abusive conditions. Shifting is still smooth, not one issue to report, and I beat on it quite a bit when I drive.
The motor is a stock ported 13B with minor power mods (intake, exhaust, etc).
Still as good as the day I dropped it in there
Old Dec 17, 2008 | 07:33 PM
  #110
HotRodMex's Avatar
While this is being brought back up...
Are there synchro differences between the two transmissions? As in, are the miata ones better, or are they essentially the same as the FC?
Old Dec 17, 2008 | 08:00 PM
  #111
Black91n/a's Avatar
The 1.8 Miata transmissions (1994+) have better syncros on one or more gears AFAIK. I don't know about the FC vs. Miata differences though.
Old Dec 18, 2008 | 03:57 PM
  #112
Pele's Avatar
Right near Malloy
I think all Mazda transmissions across the board got that update at that time.
Old Dec 18, 2008 | 05:50 PM
  #113
HotRodMex's Avatar
So when doing this project, you would want to use parts from a 94-98 transmission?
Old Dec 19, 2008 | 06:32 AM
  #114
Pele's Avatar
Right near Malloy
1994-1997. No Miatas produced in 1998.
1999-2004 has a different shifter that shouldn't matter since you're changing the tailshaft housing anyway.
Old May 6, 2009 | 10:07 PM
  #115
Shadow102's Avatar
Eneman to the Rescue
once again another from the dead bump. I am picking up a miata trans to do this. As far as the internals go what exactly from the 7 trans do you use and what from the miata trans do you use?
Old May 7, 2009 | 12:50 AM
  #116
myfc3s's Avatar
That's what she said...
I would suggest calling Mazdatrix for more info. They were the ones that installed the miata tranny. Good luck!
Old Sep 3, 2009 | 04:44 PM
  #117
Pele's Avatar
Right near Malloy
Rebumping:
Internet WAYBACK Machine!!!
Drivetrain interchange guide:
http://web.archive.org/web/*/http://...rivetrain.html
Latest edition, Circa 27 Nov 2007:
http://web.archive.org/web/200711270...rivetrain.html
5th gear interchange:
http://web.archive.org/web/*/http://...terchange.html
Latest edition, Circa 9 May 2006:
http://web.archive.org/web/200605090...terchange.html
Old Sep 3, 2009 | 05:26 PM
  #118
Molotovman's Avatar
Ban Peak
Alright, so it looks like I'm going to be installing the Miata gears\tranny in my GTUs.
I found an 01 trans with <12,000miles on it. I called up Mazdatrix and They said the best years to use are 01' and 03' and they mill the input shafts for $90! Just gotta wait a little bit, the trans is in florida and I'm in VA. It's supposed to be delivered next friday unless the deal goes bad this weekend.
I will make a new thread when the time comes.
Pele will also be participating in this fiasco.
Old Sep 19, 2009 | 12:30 PM
  #119
Pele's Avatar
Right near Malloy
Molotov and myself have 2005 and 2003 Miata transmissions respectively. (My thought that it was a 99 was wrong...)
Problem:
When dismantling the trans, how do you get the input shaft off?
1.) Input shaft snout removed
2.) Bellhousing and tailshaft housings separated from the main support plate leaving the entire geartrain there...
Pics to come later.
Old Nov 9, 2009 | 09:09 AM
  #120
Pele's Avatar
Right near Malloy
Rebumping for a link update.
All the gear ratios ANYONE would ever need: http://fm.no-ip.com/tranchrt.txt NEW LINK! UPDATED GEAR RATIOS!
Solomiata Drivetrain interchange guide: ARCHIVED INFO!
5th gear interchange: ARCHIVED INFO!
Also mirrored here:
Old Jul 30, 2010 | 08:21 PM
  #121
KusImmak7's Avatar
Dixie Normous
how the hell do you get the guts of one in the other? I have a spare s5 na tranny laying around and need to put the guts into the miata tranny but cannot manage to swap the cases...
Old Jul 30, 2010 | 08:26 PM
  #122
gear_grinder's Avatar
Don't hate my V8
if i'm not mistaken, you dont swap the cases, just the actual "guts" from one to the other. the miata input/1st gear is all one part (kinda), you have to mill a secton of the splines off to have it fit the NA FC clutch "location".
Old Jul 31, 2010 | 10:13 AM
  #123
KusImmak7's Avatar
Dixie Normous
ok with that being said how do you get the guts out? And I am doing this backwards, I am putting the fc gears into the miata box so the input shaft should be fine.
Old Jul 31, 2010 | 10:39 AM
  #124
Rx-7Doctor's Avatar
https://www.rx7club.com/showthread.p...on+interchange
Old Aug 12, 2012 | 08:06 PM
  #125
devilxavierz's Avatar
bump this back up, been reading this interesting swap. looks like im getting one from 99-05 miata!!
Wicked93gs
42
Oct 7, 2015 11:58 PM
rxlevi7
Sep 26, 2015 07:28 AM
