Autometer A/F quick question?
Old Jun 2, 2002 | 12:36 PM
WhiteRXseven's Avatar
I (actually DontbeaRikki) recently installed an
Autometer A/F gauge on my FD3S.
My question is. During operation.
Do you want to tune your car so
the light readings are at STOICH,
when on the gas???
Under normal driving condition on the gas
it reads 1-2 light green in the Rich.
Thanks..
Old Jun 2, 2002 | 01:34 PM
rizzxx7's Avatar
DIGG7ER
mine is the same way, i dont think it matters unless your at wot.
Old Jun 2, 2002 | 01:38 PM
BoOsTin FD's Avatar
Powered by** Rotary
I also want to know about reading on Autometer A/F. When idling mine is always on red , which indicates lean, however i can still hear it backfire sometimes. But when it's at wot, it's always at green. Is this ok?
Thanks
Old Jun 2, 2002 | 01:52 PM
maxpesce's Avatar
Ex fd *****
Normal readings on A/F ratio mtr are:
Idle: No LED's or just 1-2 red at lean end of scale - Not enough exhaust gas to maintain accurate readings
Part Throttle/NO BOOST: reading should fluctuate rapidly between lean & rich - cpu is in CLOOSED LOOP mode
PartThrorttle>WOT wBOOST: should read 1-3 LED's RICH (the higher the boost the more rich it should be)
Mine runs 2-3 bars rich at wot and 10psi boost
Old Jun 2, 2002 | 03:33 PM
dclin's Avatar
Perpetual Project
http://www.gadgetseller.com/gauges/index.htm
Read the part about their modification service for the Autometer A/F gauges.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZacMan
Sep 19, 2015 09:20 PM
Nosferatu
Sep 5, 2015 02:13 PM
