ACT Cluth problem anyone have this happen ?
Old Apr 22, 2002 | 08:18 PM
HotWheel's Avatar
I have noticed it smelling like I'ts burning or like when ya mis a gear ! I have a aluminum 9.5 flywheel and a ACT street strip clutch and pressure plate.
I put a speed bleeder in and blead the system clean
ajusted the pedal hight and play But it gets sticky sometimes and I smell it burning when I fire it up
just holding the pedal in When I start it !
I'm thinking it's the master slave cylinder it's original
49k but the clutch set up has 4k miles
What do ya think anyone???
Old Apr 22, 2002 | 08:41 PM
spooledUP7's Avatar
There and back again
Could be tranny oil. That stuff will gas off the tranny if you have even the smallest bit on the case.
Old Apr 22, 2002 | 09:33 PM
HotWheel's Avatar
just checked
I just checked inside the service plate and every thing looks clean, just a little dust.
I have the wife push the peddel down to see if it was working correctly I see the throw out bearing and
lever working properly !
But the clutch seems to pull away slightly, like about
less than a 1/6th of an inch when the peddel is to the floor I wonder if that is normal ? and the snap ring is
out about a 1/2 inch !
I spayed it down with brake clean and I'll test tomarrow night !
any other Ideas guy's
Thanks
HotWheel
Old Apr 23, 2002 | 07:17 PM
vosko's Avatar
Just Call Me Terminator!
my clutch master went bad on my TII and did that. it could be either the master or the slave or both. only one way to find out
Old Apr 24, 2002 | 05:59 AM
mmaragos's Avatar
That happened to me before I replaced the stock clutch (the sticking). I now have an ACT clutch and LW FW.
I had to replace the master and the slave too. That was at about 84K.
Since I did that, no problems. I put in a stainless braided hose too (to the slave). Figured that I might as well upgrade that at the time.
Old Apr 24, 2002 | 07:08 PM
HotWheel's Avatar
Thumbs up Thanks For the Input !
That's What I thought , I ordered mine today $70 bucks
Should have it Friday ! I'll let you guy's know
Thanks For The Help !
Old Apr 26, 2002 | 10:34 PM
HotWheel's Avatar
Thumbs up Found the Problem !
I replaced the Cluth slave cylinder ! Nope that's not it
wasted $70 bucks started to remember what RX7TT
said so I checked the bolts on the pressure plate and Bling Bling they were loose !!! (about hand tight ) !
So I took them out 1 at a time and put locktight on them !
Tested it and Walla problem Solved !
Thanks RX7TT
troym55
23
May 25, 2016 12:42 PM
Tem120
Sep 7, 2015 09:53 AM
