New Mod, made a motor mount
Old Feb 19, 2002 | 03:23 PM
turbovr6's Avatar
Ever notice how our engines are only held in by 2 tiny mounts at the bootom? Obviously with the torque our engine s put out, it's really not enough. I'm in the process of taking care of this problem by addin a 3'd mount in the engine bay to keep the motor from twisting under heavy acceleration. My prelininary tests are going well. Unfortunatly this will only work for cars with no airpump, but I'm working on that, as well as looking into a hydrolic type strut to save space, which would make it possible to work in any FD.
Why I'm doing this? I put new mounts in my car a year ago... I changed my oil pan gasket on thursday, and while I was under there I seen that I broke one allready. Cheap *** crap!
Old Feb 19, 2002 | 03:28 PM
martini's Avatar
Hmm, are you going to write a how-to? It looks much superios to the torque control arm.
Old Feb 19, 2002 | 04:07 PM
turbovr6's Avatar
Once I get a final design figured out and working 100% to my satisfaction, I'll post a how to along with materials needed. I'd like to go with a hydrolic type setup, but they are expensive, but less space consuming. If not I will keep the same mount but change the rubber bushings to polyurathane.
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
