Power Door lock in an FD: Wiring question.
Old Aug 25, 2003 | 11:16 PM
InsaneGideon's Avatar
Still on 1st engine
Question Power Door lock in an FD: Wiring question.
I'm installing a power doorlock actuator in an R2 FD drivers side door. Since I don't have the Bose system, the amp power wires are there in the door harness, but unused. I tapped into those for use on the actuator expecting to cut them inside the cabin and hook them up to the relays.
Too bad they don't exist on the interior side! They dissappear at the body connetor.
So how are you guys routing wires to the actuators?
Thanks,
-IG
Old Aug 27, 2003 | 02:19 AM
Still on 1st engine
I've seen mention of drilling through the body connector, but where does this happen? It's a tight place to be drilling.
Old Aug 27, 2003 | 10:26 PM
Still on 1st engine
Ok, maybe this will help. This is the connector I'm talking about. Does anyone know how to disengage this? I tried squeezing the blue part, but it didn't feel like it was going to release.
This is the driver's door jamb. You can see the door seal on the left.
[now let's see if I can post a pic ]
Thanks,
-IG
Old Dec 23, 2004 | 08:39 PM
gambit023's Avatar
Question
Someone please answer this guy.. it's been over a YEAR!!!
BTW i'm doing the same exact thing.. i can't get this damn plug to disconnect. Does anyone know how? i can't seem to sqeeze on it do disconnect so i'm suspecting it's some type of clip??
Can someone please tell me how to disconnect the plug mentioned above?
Old Dec 27, 2004 | 09:38 AM
look on the top side of the plug from the door jam. you will see a small lever on the top side of the connector. Push down on it with a flat head and pull the connector out from in between the door jam.....not from the interior foot where the clutch pedal is.
streetlegal?
Mar 17, 2022 02:46 PM
Th0m4s
Feb 26, 2019 02:04 AM
