Air Intake Temp sensor........
Old Jul 1, 2003 | 10:59 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Question Air Intake Temp sensor........
Ok I want to setup the intake sensor for testing later on this month. Where would be the best location for it? I was just thinking of putting the probe into the black hose right after the AFM But I need someones own experience. Also I was going to buy the one from CSI but would like to buy something a bit cheaper unless that is cheap. lol
Santiago
Old Jul 1, 2003 | 11:54 AM
Zach McAfee's Avatar
FTD Wanna Be
I think for your experiment, right after the AFM would be best for comparison, maybe even at the entrance of the AFM, since you know the standard cone filter will take in engine bay temps. You could just leave the CAI on and still take both measurements (CAI intake temps, then engine bay temperature at the AFM).
Does that make sense?
Old Jul 1, 2003 | 03:43 PM
1987RX7guy's Avatar
Yes this is what I planned. Thanks! Does anyone use the CSI sensor/guage? It is the 52MM model that goes up to 300 Degrees.
Santiago
Old Jul 1, 2003 | 03:57 PM
HAILERS's Avatar
HAILERS
Buy a Fluke 52II http://www.tequipment.net/FlukeThermo52.html
Old Jul 1, 2003 | 04:00 PM
1987RX7guy's Avatar
Interesting but the guage and sensor will cost me less than that.
Santiago
Old Jul 2, 2003 | 01:32 AM
NZConvertible's Avatar
I'm a boost creep...
If this is to be a permanent fixture, it should be mounted as close to the engine as possible, but in a fast moving airstream. In the plastic intake pipe close to the TB would be best.
Try to find a gauge with a lower scale, like up to ~200degF. If the intake air on a NA gets that high you have problems, so 300degF is totally unnecessary.
Old Jul 2, 2003 | 09:00 AM
1987RX7guy's Avatar
NZ you have any reason for placing it in that location?
What brand would you recommend?
Santaigo
Old Jul 2, 2003 | 11:52 AM
1987RX7guy's Avatar
Ok guys, What is the cheapest accurate boost guage I can buy?
Old Jul 2, 2003 | 12:27 PM
HAILERS's Avatar
HAILERS
why are you measuring air temps??? Cheap AND accurate????? Maybe Autometer. Fifty to sixty bucks (wag).
Old Jul 2, 2003 | 12:58 PM
Nick86's Avatar
Yup, still here
Summit Racing:
Nordskog digital guage:
You can get it in green/red display.
Old Jul 2, 2003 | 03:32 PM
1987RX7guy's Avatar
Thanks Nick!
Old Jul 2, 2003 | 09:56 PM
1987RX7guy's Avatar
What about a boost guage? I want to see if I can design a good ram air scoop to add to my intake. Maybe get like 1-2 PSI lol
By cheap and accurate I just mean which ones are GOOD but not 300 dollars(sarcasm).
Thanks
Old Jul 2, 2003 | 10:08 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Originally posted by Nick86
Summit Racing:
just make sure you get the sender as well. it's sold serprate.
I use those for oil and water temp. I like them alot.
Old Jul 2, 2003 | 11:23 PM
1987RX7guy's Avatar
scott I PM'ed you.
Old Jul 2, 2003 | 11:27 PM
Scott 89t2's Avatar
SOLD THE RX-7!
crapometer
Old Jul 2, 2003 | 11:33 PM
1987RX7guy's Avatar
Old Jul 3, 2003 | 12:49 AM
Because it'll be the most accurate measurement of the air that's actually entering the engine, short of actually putting it in an intake runner. You'll notice that's where the 13BT's sensor is located.
If you into DIY electronics, this is one I really like. The article also has some good info explaining why keeping intake temps as low as possible is so important.
Digital Temp Display
Old Jul 3, 2003 | 08:02 AM
Nick86's Avatar
Yup, still here
Unlike the water/oil temp guages, this one actually comes with the sending unit. If you go to the page on the Summit site, and press on the "Technical" tab, it tells you that the sender is included.
Old Jul 3, 2003 | 10:00 AM
1987RX7guy's Avatar
Nick86- Thanks man, that guage is great.
I have been looking at some mechanical boost guages for now to see if I can make a Ram Air scoop for the filter. Are mechanical good or bad?
Old Jul 8, 2003 | 08:11 PM
1987RX7guy's Avatar
How hard would this be to instal? I have never put in a guage before so I am a dummy. :-/
Old Jul 8, 2003 | 08:30 PM
Aaron Cake's Avatar
Engine, Not Motor
A vendor asking how to install a guage?
Really, it would not be hard to install. You will need to install a sensor (I assume we are talking air temp) in the intake which probably involves drilling and tapping a hole in the manifold. Run the wires, mount the guage where you please (I like guage pods or the vents above the logicon) and connect things up.
Mechanical guages are generally cheaper, but electrical guages are more convenient to install since you are not running hoses and stuff. Both should be just as accurate if you buy quality parts.
Old Jul 8, 2003 | 08:34 PM
1987RX7guy's Avatar
Nothing wrong with asking man.
Thanks for the info.
Old Jul 8, 2003 | 08:38 PM
Aaron Cake's Avatar
Engine, Not Motor
Didn't say there was.
Matlock's Avatar
Ahahahahahaha! Stop your killing me. Archive this ****, it's the BOMB! ahahahaha
Old Jul 8, 2003 | 08:41 PM
marcus219's Avatar
FC Mobsta
DA BOMB! AZ Tech Rotary...
Maybe you'll put down some serious power!!!
