3800 hesitation questions
Either your secondary injectors are getting sticky/plugged and you need to run some injector cleaner through there, or you have bad grounds on your engine and you should run some new ground wires (such from the negative battery terminal to the frame, and from the frame engine block) Sometimes that doesn't help, and you have to reground the ecu, that ones a little more difficult and I suggest you search for a thread on how to do that one.
rgordon1979
40
Mar 15, 2022 12:04 PM
Adaptronic S5 Turbo PNP Unit questions
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
