ram air from the second oil cooler duct - pic of my setup
Old Mar 8, 2003 | 09:51 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
had some requests on how I routed the ducting, so here are the pics:
Old Mar 9, 2003 | 04:12 AM
Tomco78's Avatar
Nice setup!
But now, waaay off topic; what are those tires you're running there?
Old Mar 9, 2003 | 04:16 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
tires are:
Dunlop
SP Sport FM901
they are not bad for the track, and good for the street...cheap too, got mine from tires.com
Old Mar 9, 2003 | 06:19 PM
ttb's Avatar
ttb
No Cup Holder Racing
do you notice any different?
Old Mar 9, 2003 | 07:05 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
can you elaborate on ur question?
Old Mar 9, 2003 | 07:11 PM
Mld>7's Avatar
I Post Mad Quick Yo!
I think he ment perfomance wise..
Old Mar 9, 2003 | 07:28 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
not yet, still snow on the ground here so its not coming out of the garage yet...
Old Mar 10, 2003 | 01:20 AM
jpandes's Avatar
I did the same type of ducting using flexible plastic/metal coil intake ducting that I bought from Kragen($10) I had enough to run two ducts; one from the oil cooler spot and one from next to the left fog light. I tried that ducting material that you have in your pic and had bad luck with it. It just pulled apart. BTW, I saw your post of the custome heat shield that you made. AWESOME.
Old Mar 10, 2003 | 01:35 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
Originally posted by jpandes
I did the same type of ducting using flexible ... BTW, I saw your post of the custome heat shield that you made. AWESOME.
Old Mar 10, 2003 | 11:51 AM
styxx8602's Avatar
Thats a pretty good invention but i have a question.What about the cooling for the brake? Now theres absolutely no air cooling the brake on that side?
Andres
Old Mar 10, 2003 | 11:57 AM
on my 94, there was a plastic piece blocking the entire hole. definitely no brake cooling going on there.
Old Mar 10, 2003 | 12:41 PM
styxx8602's Avatar
Yeah thats true. I had that thing covering the hole too. But i was just wondering if it has any long term effect on the brakes.
Andres
93 Touring
Old Mar 10, 2003 | 04:14 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Andres
well, the entire thing was blocked before, so there was no air flow in there anyway, and i think ur confused, the brake air cooling flow comes from ducts in teh r1 spoiler lip
Old Mar 21, 2003 | 09:27 AM
Turborl7's Avatar
do you have any meshing to prevent debris from flying into the engine area?
Old Mar 21, 2003 | 09:46 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
no, but its a good idea.... the tube does turn upward so at least gravity helps keep some crap from making it to the filters
Old Apr 30, 2003 | 12:39 PM
airborne's Avatar
King of the Duct Tape
thought i'd dig this thread up and say i did this mod, probably slightly different path on the ducting but that would be the only difference.
and it works great. at any speed, even as low as like 15mph, the temp around my filters rapidly drops toward the outside temp. i have two radio shack temp sensors in there to measure it, and the one closer to the end of the duct reads consistently lower than the one just a few inches away.
one question if damian is around or anyone knows:
best way to mount to the hole in the spoiler? right now i've got it duct taped but its kinda ugly....
Old Apr 30, 2003 | 01:14 PM
jpandes's Avatar
[i]
best way to mount to the hole in the spoiler? right now i've got it duct taped but its kinda ugly.... [/B]
I used zip ties. I drilled two small holes at the back of the bumper to run them through.
Old Apr 30, 2003 | 01:27 PM
airborne's Avatar
and zip ties through the duct? i didn't want to cut it too much for fear it would start a big rip. holdin up ok though huh? hmmm...thanks
Old Apr 30, 2003 | 01:35 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
pics on how i used the stock cap as a mounting base:
Old Apr 30, 2003 | 01:41 PM
airborne's Avatar
damn, yeah i need that cap...
here is what i'm using to measure temps
http://www.radioshack.com/product.as...5Fid=63%2D1035
its cheap but shows temp where the remote sensor is up to 70C and also shows the temp for where the main unit is. $20.
Old Apr 30, 2003 | 02:02 PM
matty's Avatar
impressive
Old Apr 30, 2003 | 02:08 PM
airborne's Avatar
i could do something 'impressive' too if i had that dang piece...sorry, sorry. just bitter.
Old Apr 30, 2003 | 02:15 PM
matty's Avatar
is that bracket only on the R models or something?
Old Apr 30, 2003 | 02:17 PM
airborne's Avatar
i think damian had it and his isn't an R1. i think my pos just lost it along the way somewhere...
though it is kinda unnecessary on non R1 models...
Old Apr 30, 2003 | 02:28 PM
GoRacer's Avatar
Speed Mach Go Go Go
Very creative
I thought about that but never followed through with it. I was going to buy that stuff they use on race car windows for the drivers to get air, but I was gunna drill a hole instead of going underneath. I found some mounting plates with a short tube to mount the flexible hose on both sides and clamp them on. I wanted it to be strong at high speeds. I've even thought about using silicone hose but it was too expensive.
