I have turned to the dark side NA -> TII
Not sure if any of you have seen some of my recent technical posts lately. But I have been discussing the different power ranges with different naturally aspirated motors. Here is one good post to show ya: https://www.rx7club.com/forum/showth...hreadid=153873
With all these different options in porting, induction, etc. to get the power that I would want would make the car not very un-streetable. This would be ok if I was going to make it a race only car and tow it to the track. But at this time in my life I don’t have the cash to be doing that and I still enjoy driving it on the street. With this in mind I have come to the conclusion to go turbo. I know I have poked fun at the turbo guys for a long time now. But remember it was only fun and now I expect to get the same treatment when I do a post in 6 months to a year titled “I blew up my motor”.
I will be doing a step-by-step document/write up of the N/A to TII conversion process for the S5 cars. I will take as many pictures as it takes to show the process (just hope my web hosting server does not run out of space
) I am adding one step to this process, rebuilding the motor. I will be leaving this out due to the fact that most of you know what is going on there, or if you don’t try using the search button there are many who have done write ups on that.
My goal for this project is not to hack up the GTUs but to make it the cleanest install that is humanly possible. Kevin watch out my engine bay is going to be cleaner than yours!!
So far I have purchased the following parts:
- S5 TII motor complete minus some sensors, bolts, little things.
- S5 TII engine wiring harness
- S5 TII transmission
- Old style HKS front mount intercooler (with both pipes on the passenger side)
- HKS super sequential BOV
- HKS extra injector controller wiring harness with 2 650cc injectors mounted on the TB pipe adapter (I got it with the FMIC, might sell that)
Parts I need to finish the job:
- S5 MAF, N370 boost sensor, N370 ECU, Knock sensing ECU/CPU, TPS, Idle solenoid (mounted on upper intake hose connected to BACV)
- Down pipe and main cat
- New silicone connecting hoses for the FMIC
- Better turbo hose clams
- New silicone hose set (in black no weird color vac hose in my engine bay)
- S5 550cc primary injectors
- S5 720cc secondary injectors
- Almost all of the intake manifold bolts
- S5 TID
- S5 oil injectors
I will keep you all updated, and if anyone has info on the parts I still need let me know.
) I am adding one step to this process, rebuilding the motor. I will be leaving this out due to the fact that most of you know what is going on there, or if you don’t try using the search button there are many who have done write ups on that. My goal for this project is not to hack up the GTUs but to make it the cleanest install that is humanly possible. Kevin watch out my engine bay is going to be cleaner than yours!!
- S5 TID
- S5 oil injectors
Originally posted by darkwaveboi
need a stock downpipe/precat or are you going aftermarket
Rotary Racer "Officaly banned from Team GTUs"
What i was planning on doing was have a stock cat bolted to a precat/connecting pipe, and swapping that in for emissions. I think 3 days of work putting the ACV/airpump back on are worth the 100 or so bux you save on bribery.
Trending Topics
Originally posted by SonicRaT
There's not much need for a writeup, it's basically unbolt and bolt back in. It's pretty easy, but good luck!
----What you think people should I do a super write up or no? Net me know?----
Thanks neevosh, nothing compares to the power of the dark side of the force!!
Rotary Racer "that rug rely tied the room together, man"
Well, it's been done before. That's the problem, people ask regardless of the fact it's been covered about 5 or 6 times. It's really up to you, if you're up for it go ahead, but chances are it'll end up in the vault hidden from everyone like all the rest.
"I just be biting other peoples style"
Re: I have turned to the dark side NA -> TII
Originally posted by Rotary Racer
[BParts I need to finish the job:
- S5 TID
- S5 oil injectors
I will keep you all updated, and if anyone has info on the parts I still need let me know. [/B]
- S5 TID
- S5 oil injectors
mike
Mike: I am going to stay with my GTUs 4.30 rear end. I don’t think I will ever go over 300 hp (crank hp). I have faith that my rear end will hold. And if it doesn't then I will buy a TII rear end rebuild it with a Kazz 1.5 LSD and 4.30 gears
Another question so any 2 bar MAP sensor will work? Like one from a S4? I was not sure because the MAP sensor has the ECU code on it and I know how Mazda likes to make different electrical parts.
Rishie: Goal is to be C.A.R.B. approved so I am sticking with stock ECU. And after the sticker/approval plate is on my car I will be bolting on a piggy back and the 720cc secondary and some other goodies
"got to love them Mazda electronics
Another question so any 2 bar MAP sensor will work? Like one from a S4? I was not sure because the MAP sensor has the ECU code on it and I know how Mazda likes to make different electrical parts.Rishie: Goal is to be C.A.R.B. approved so I am sticking with stock ECU. And after the sticker/approval plate is on my car I will be bolting on a piggy back and the 720cc secondary and some other goodies
i would use the stock na ecu to run the smog system, and piggy back a standalone to run the fuel and spark, that way you dont have to find s5 t2 specific stuff
mike
Yo,
Blasphemy!!
*grin*
Dana, your car should be badass when it's done. It'll be like an Infini IV...but without the rear wiper!! Heh.
Kevin
1989 GTUs "The Farce is strong in this one..."
Blasphemy!!
*grin*
Kevin
If you do it right it is VERY rewarding, 300 hp up from 170 180 or so is a huge change. 15psi, greddy 2row, e6k, avcr, 550/1600 full -an, sx fpr, walbro, safe and fun. Oh and I am 16. It was a huge learning experience.
I don't believe a rightup is needed unless it is strictly a trouble-shooting guide.
i can't approximate crank hp to wheel hp, but when i was thinking about building my N/A, i was told i could have 250whp with no problem by a local rotary guru mechanic. i know it can be done, and said to still be streetable, so you don't *have* to go turbo to get that 300 max crank horsepower.
You can find a s5 TII harness and ECU, it's just not easy.
I had 3 of each at one point in time. I think I've still got a spare n374 ecu somewhere. Anyway, I don't believe just any 2bar map sensor will work, but you're welcome to try, I think mazda really had a knack for making things in their own way.
kind of off topic, but if you're looking for webspace... take a look at addaction.net, i'm getting my hosting done there, pretty cheap... there's a plan that's got first 6 months free, 7 bucks a month afterwards, 500 megs of webspace and 10 gigs of bandwidth per month and all sorts of goodies... i like it... although i haven't done much with mine yet...
Thanks for the support people. I already have the wiring harness just need the MAF (if I have to will buy from Victoria British 199+core), boost sensor (got to be some one who has it, N370 ECU (calling Mazda recyclers tomorrow
), not sure where to get the knock sensing ECU/CPU, TPS (expensive but buyable).
Mike: I had already figured I would have to do something like that for the drive shaft. I think I will use the N370 ECU. If I use the N/A ecu and put on a piggy back to make it work from the get-go it will not pass C.A.R.B. approval.
Kevin: Thanks, you know I would only do it if I could do a super clean job, and use the Mazda correct parts
Suds7: Woooooow hold on tiger. I just want to do a swap not take out spend a billion dollars.
Casio: I have been spending a lot of time thinking and tinkering on the NA’s and this is the way I have to go. But thanks for tying to pull me back into the light.
SonicRaT: I agree with you on the boost sensor. If Mazda gave it a different part # I think I should use it
Poor…: Thanks I will look into it.
), not sure where to get the knock sensing ECU/CPU, TPS (expensive but buyable).Mike: I had already figured I would have to do something like that for the drive shaft. I think I will use the N370 ECU. If I use the N/A ecu and put on a piggy back to make it work from the get-go it will not pass C.A.R.B. approval.
.Suds7: Woooooow hold on tiger. I just want to do a swap not take out spend a billion dollars.
.Poor…: Thanks I will look into it.
