Here it is.. no more FTPs!
Old 02-25-03, 03:24 PM
chaos7's Avatar
Ok. This takes a long time to write, so bear with me.
Here is what you probably want if youre referring to this thread. These are real pics of my car with this mod finished.
Before you start you'll need:
Fiberglass mat
Particle respirator (mask thing)
4 pairs of latex gloves
Resin and liquid hardener
Something to cut with, (die grinder and dremmel)
"L" brackets from home depot
Some kind of body filler
That clear plastic packaging tape. Yes, the fat one. Not to be confused with scotch tape.
Celebratory beverages.
Arite. Here it is.
1. Take off the bumper cover. Do not forget about your bumper lenses.
2. Remove the bars that go across the headlights and there will be two big screws on the hard safety bumper that go across those holes. Remove those also
3. Take off the metal brackets from the top of the bumper cover. (LEAVE IN THE SIDE BRACKETS WITH THE SCREW THINGIES IN. TAKING THESE OFF WILL SUCK BADLY LATER.)
4. Remove the ftp lenses and foam things
5. Discard the shorter metal pieces from the upper support frame (there should have been 3 pieces there to begin with)
6. Mark the front of the bumper cover where you want to cut with a pen or something
7. Take a die grinder or something and cut the bracket backing part that usually sits behind the ftp lenses.
8. You should now have completely empty ftp lens holes.
9. Now stare at your bumper. This is the point of no return. Yes. It really is.
10. Cut the part that you marked earlier. I just continued the lines up from the lens hole. Do not use a dremmel cutting wheel for this. It will break because the part that youre cutting will melt and grab hold of the wheel, breaking it. Very wasteful.
11. Ok, So now you should have 2 big holes in your bumper cover.
12. Cut the metal frame thing accordingly
13. Place the bumper cover on the ground, the colored part facing up.
14. Take the packaging tape and form the walls of the part that you want to add. Make sure you do this from the outside. If you do this from teh inside of the bumper, it wont work.
15. Support with the L brackets
Ok so now you have a makeshift mold.
16. Cut and place the fiberglass in the part that you want it. make sure there is enough excess hanging over and into the inside of the bumper.
Wear latex gloves for this part
17. Brush the resin generously all over the fiberglass.
18. Poke the bubbles with a small screwdriver while its still wet.
19. Now let it dry overnight
20. If its dry, remove all the tape.
21. remove all the spots that the resin ran over accidentally.
22. Place the bumper back on the car
23. Sand the hard corners with some heavy grit sand paper.
Wear gloves for this part also.
24. Take some body filler and smoothe out all corners that you want ot be rounded.
25. Smoothe out the parts that arent level too.
26. Take sand paper, dremel and other sanding stuff and sand the filler.
27. Fill all the little holes that the bubbles left over from the filler.
28. Sand. and trim parts that hang over too far into the car with a cutting wheel
29. Wash up and open celebratory drinks.
30. Paint.
Old 02-25-03, 03:32 PM
Newbie
gunluvS14's Avatar
very nice write up. We should save this on the archive.
Post more pics later on.
Old 02-25-03, 03:33 PM
Do a barrel roll!
Rxmfn7's Avatar
Damn nice job
Old 02-25-03, 03:36 PM
Your Opinion is Wrong
Dyre's Avatar
Looks like an 80 z car.
Old 02-25-03, 03:40 PM
chaos7's Avatar
The dark areas around the cutouts arent a lip that goes up, its just the camera angle and a part that hasnt been polished yet
Old 02-25-03, 05:00 PM
that looks really good.
good job!
Old 02-25-03, 06:02 PM
Now with more 1st Gen!
autocrash's Avatar
One more question: Any new dark areas because of this? (ie. are the sides still well lit? (it looks like it could really restrict the field of view as a result... (to small of an angle inside))
Old 02-25-03, 06:08 PM
What Subscription?
banzaitoyota's Avatar
Looks nice, but please let us see this summer when the bumper and fiberglass heat up and crack. They have substantiallt different rates of expansion and contraction. You probably should have used a product designed for repairing bumpers
Old 02-25-03, 06:28 PM
pei > caek
dr0x's Avatar
I will attest to not using a rotary tool to remove material off the bumpers. I did last night and used ATLEAST 20 cutting wheels (I have a big box of them) on my front end project (nothing like this). I have all sorts of little ******* cuts all over my arms from when the blades shattered. Oh well
And I agree, you should have used the proper material for our bumpers and not fiberglass. I forget whats it called, look up a thread I made about FTP lenses, someone links a site that talks all about it.
Old 02-25-03, 06:59 PM
What Subscription?
I did ts the norton site, even has vids on how to use it
Old 02-25-03, 07:48 PM
turboren's Avatar
You know, I was trying to think all day what that reminds me of, and now I remember... 3rd gen Camaro. And with that being the case, it probably should light up the road ok, even as far recessed as it is. It will probably have less light on the sides, though. I don't think that can be avoided without moving the lights themselves farther forward somehow.
FWIW, the 924GTS had a similar setup, except they replaced the headlight covers with plexiglass and moved the lights up even with the bottom. More like the original AE kit for the FC, I guess.
Ren
Old 02-25-03, 08:01 PM
turboren's Avatar
BTW, you have a head-on shot of this? I bet it looks a lot better from the angles you shot it than it does from the front...
Ren
Old 02-25-03, 08:07 PM
my_jdm_rx7's Avatar
And what IS the proper material to use? What is wrong with what he used?
Old 02-26-03, 12:47 AM
chaos7's Avatar
Hey... it was just a boredom project. If you guys dont care for it, so be it. I'm not gonna keep this front for much longer as im going to start a new project hopefully this summer. I really havent seen fiberglass simply crack from normal heat - i live in the bay area (it really doesnt get too hot). The filler might crack, but i care not. Ill post a pic more towards the front in a bit. ill take some more pics from directly in front.
Old 02-26-03, 12:53 AM
chaos7's Avatar
Ren
It actually looks decent from straight on. ill try to get some pics up soon. i still have to take them. The reason why i didnt take some from directly in front is because there was a car parked there and i couldnt squeeze in back enough to get a decent shot
Psychoblue23's Avatar
Nice job chaos... Wanna do another one.. aww cmon I am close enough!
*lol*
- James
Old 02-26-03, 12:58 AM
chaos7's Avatar
If i help you on yours, we'll have to research the "correct ingredients" as said above. i dont wanna do an almost job on someone else's car.
Old 02-26-03, 01:04 AM
Kim
OBEY YOUR MAZDA
Kim's Avatar
Good job dude, I like it
Old 02-26-03, 01:35 AM
I break Diff mounts
Digi7ech's Avatar
kinda looks like a late 80's early 90's Camaro front lights except just one instead of 2.
Not bad looking though.
Old 02-26-03, 04:30 AM
Lava Surfer
bingoboy's Avatar
so i assume you made it so the lights dont pop up right?
Old 02-26-03, 07:00 AM
B O R I C U A
KNONFS's Avatar
That's a good question! And if not, How is the night visibility?
Old 02-26-03, 07:39 AM
What Subscription?
Like I said: You did a nice job, you just used the wrong materials. Here is a link:
www.paintucation. com DIY Auto Painting Board
www.nortonautomotive.com/...howto5.asp Plasic Bumper Repair videos
I am just pointing out the incorrect choice of materials so someone elese does not make the same mistake
Old 02-26-03, 07:56 AM
13B N/A POWA!
KiyoKix's Avatar
Looks good, but does remind me of an '80's Z car .
Old 02-26-03, 12:04 PM
Daily Domestic Killer
BlackRx7's Avatar
yeah you need to fill in the head light covers with the hood now, though it does look pretty good...
Old 02-26-03, 12:11 PM
Great Job! I like, me think me make it on mine.
Al
Quick Reply: Here it is.. no more FTPs!
