Remote mounting sending unit for aftermarket gauge.
Old Jan 22, 2003 | 03:25 PM
13bpower's Avatar
s4 for life
1.
I am installing a autometer oil pressure gauge on my 88.
The problem is the sending unit cant fit in the tight space the stock sending unit fits in.
I believe I need a braided steel line with the proper fittings on each end. That way I could remote locate the sending unit. Is this correct?
Also where can I get this kind of line and the proper fittings?
2.
I am also installing a autometer water temp gauge. The sending unit included with my gauge is to big (larger than the stock hole) to fit in the stock area.
Do I have to use the aftermaket sender. Would using the stock sender mess things up?
Thanks,
Steve
Old Jan 22, 2003 | 03:36 PM
Nick86's Avatar
Yup, still here
Are they electric gauges?
I have an autometer electric oil pressure gauge, and the sending unit was a PITA. The thread of the sending unit is 1/8 NPT, but the thread of the block is not. You need to go to a hydrolics shop and get a 1/8 NPT to 1/8 BSPT adaptor. This little thing will let you screw the sender into the stock location.
As for the water gauge, many people drill and tap a whole in the thermostat housing. There has been some recent threads about mounting the sending unit from a water temp gauge. There were some pics too. I'll see if I can find the thread....
Here's one:
https://www.rx7club.com/forum/showth...5&pagenumber=1
Here's a better one:
https://www.rx7club.com/forum/showth...t=Coolant+Flow
Old Jan 22, 2003 | 03:51 PM
13bpower's Avatar
s4 for life
Thanks Nick, BIG help.
So keeping the stock water temp sending unit and tapping the thermo housing for the aftermarket is the way to go?
LMBTG
Aug 15, 2015 01:43 PM
