HELP ball joint broke
Old Jan 13, 2003 | 01:35 AM
Pumped's Avatar
its the ball joint on the front lower control arm.
i was very lucky it did'nt happen when i was driving fast.
it happend going like 2 mph. the front wheel caved in.
damm i'm unlucky, does this happen to 3rd gens often?
i have stock suspension with 65k miles
i hope its not too expensive to fix.
Old Jan 13, 2003 | 04:12 AM
maxcooper's Avatar
WWFSMD
A new lower control arm is needed to fix. About $500 for the part.
-Max
Old Jan 13, 2003 | 12:00 PM
Scrub's Avatar
bow leggin'
Damn, that sucks. Thats a lot to fix too. I would also like to know if that is common. I highly doubt it.
Old Jan 13, 2003 | 12:06 PM
paw140's Avatar
Actually, you're REALLY lucky. Something like this could total the car if you were going fast.
I've never heard of it happening to anyone else.
Old Jan 13, 2003 | 03:59 PM
VFactor24's Avatar
yep this same thing just happened to me last month and it ended up costing me 750 bucks to fix with labor. With a broken ball joint u have to replace the whole lower a arm
Old Jan 13, 2003 | 04:00 PM
VFactor24's Avatar
this also happened to me while i was going 2 mph. I was getting gas and then 2 seconds later my right front caved in
Old Jan 14, 2003 | 03:07 PM
Pumped's Avatar
Hey VFactor24
How many miles did you have on your car when you joint busted??
do you autox/track your car at all..
i'm just pretty choked that that pos fell out.. I usually don't corner too hard, and only autox'd the car one time for about 4 runs
Old Jan 14, 2003 | 06:39 PM
VFactor24's Avatar
right now i have 92k my suspension set up being completely stock
Old Jan 14, 2003 | 11:05 PM
turbojeff's Avatar
Do it right, do it once
It would really help if you could show some pics of how it broke. I've never heard of them breaking before, it would be nice to see where it broke.
Jeff
Old Jan 15, 2003 | 09:39 PM
Pumped's Avatar
sure, i'll take pics tommorow
Old Jan 16, 2003 | 12:41 AM
machinehead's Avatar
kortez
Did either of you notice anything unusual about the way the car was handling before your ball joints broke? Did the front feel sloppy or anything, or fine up to the point that it broke?
Old Jan 25, 2003 | 12:11 AM
Pumped's Avatar
it felt normal, then all of a sudden it collapsed
Old Jan 25, 2003 | 04:37 PM
VFactor24's Avatar
the only pics i have is how my front right tire was resting on teh front right fender. The car felt perfectly fine, i hit an exit ramp at the usual speed and then when i went to get gas it just collapsed. Pretty much when i looked under the car the whole lower control arm was off resting on the inside of the rim.
Old Jan 25, 2003 | 05:20 PM
CCarlisi's Avatar
Rebreaking things
jesus. that scares me. I drive around in boston potholes. My car has 69k on it (getting old, still remember when it was in the 30s). If I can get a set cheap maybe I'll swap my control arms out when I install the rest of my suspension stuff next month. That's really irresponsible of mazda. I udnerstand the benfits of having light suspension parts, but I would be willing to give up 100 grams per side for piece of mind, or alternately pay a little extra to have them manufactured better. But I'm sure mazda used the optimal method to produce these parts as they did with other items such as the 93 wheels, center counsole finish, exterior finish, ect.
Old Jan 25, 2003 | 05:39 PM
VFactor24's Avatar
Old Jan 25, 2003 | 05:40 PM
Jedon's Avatar
Slave2TheFD
I have a complete FD suspension for sale, off a 55K miles 93 R1 if you need a used replacement.
jedon@nopro.com
-Jedon
Old Jan 25, 2003 | 06:13 PM
CCarlisi's Avatar
Rebreaking things
thanks Jedon, but I think I will replace them with new parts since I'm concerned about their fatigue strength.
V, looks like a clean car otherwise
Old Jan 29, 2003 | 12:13 AM
Pumped's Avatar
Originally posted by VFactor24
thats exactly what my car looked like
Old Feb 7, 2003 | 03:00 AM
Pumped's Avatar
here's some pics of the lower control arm
Old Feb 7, 2003 | 03:04 AM
Pumped's Avatar
the ball
Old Feb 7, 2003 | 03:09 AM
Pumped's Avatar
close up of the socket
Thanks to Cyberben3 my cars back on the road
Old Feb 7, 2003 | 10:23 AM
VFactor24's Avatar
thats pretty much how mine looked too
Old Feb 7, 2003 | 11:29 AM
rxshun7's Avatar
I haven't posted since I've sold my FD, but I thought that this post would be worth contributing to. I had the same problem with my '93 with 90k miles. My ball joint on my passenger side also failed as I was making a slight right turn in front of my house at about 5mph. The suspension felt fine with no prior warnings of of damage before it failed. After the joint popped the front right side of my car dipped and I felt like the car hopped and skidded a little. I got lucky and found a lower A arm at a Japanese motor importing company for $50. For the next 6 months after I had the arm replaced I didn't experience any further suspension problems. I assume that the car is holding up fine to this day. So I wouldn't be too concerned with replacing the arm with a used one. You would save a huge sum of money because dealer parts cost an arm and a leg. I was very surprised and disappointed when this happened to me.I bet you were thinking WTF? Good luck and I hope this doesn't happen to anyone else.
Old Oct 29, 2003 | 09:02 AM
suganuma's Avatar
no
Old Oct 29, 2003 | 10:19 AM
pomanferrari's Avatar
This is the first time I've seen of this. Typically if your ball joint starts to go bad, as you go over bumps, your steering wheel would oscillate.
In any case, I replaced my 97K arms with 10K miles arms.
