Slim HEadlight look
Old Dec 27, 2002 | 11:42 PM
DRex's Avatar
Slim HEadlight look
I read somewhere that you can make it so the headlights only raise halfway. Does anyone have info on this.
Thanks
Old Dec 27, 2002 | 11:43 PM
bcty's Avatar
Boost This!
fuse under the hood
Old Dec 27, 2002 | 11:48 PM
Ryde _Or_Die's Avatar
Originally posted by bcty
fuse under the hood
I guarantee he has not been educated what-so-ever.
Alright pull the "retractor" fuse under the hood from the fuse block on the driver's side of the engine bay. Then under each headlight on the bottom of the car there are little ***** to turn that will raise each headlight slowly. Raise them where ever you want and you are good to go.
Old Dec 28, 2002 | 12:10 AM
BadBoy's Avatar
that is a totally lame trick...hehe just buy a headlight kit or low profile relay switch...do a search on the net for pop up light switches. or custom fabricate some of your own.
Fred
Old Dec 28, 2002 | 10:30 PM
vaughnc's Avatar
knowledge junkie
there's a mod that allows you to control the height of the headlights from inside the car via a turn-****. Here's one setup from sevenstock 5. This is Aerodyne Industries car ( www.aerodyne.net )
Old Dec 28, 2002 | 11:37 PM
MazdaRx7Racer4Life's Avatar
I AM A THIEF!! READ THE FEEDBACK SECTION!
hey, where can i get the guage pods that go where the warning light cluster used to be?
Old Dec 28, 2002 | 11:49 PM
20B10AE's Avatar
Gone Darkside
The controller you're looking for is made by Pivot. I'm reasonably certain that you can get it throug Options Auto. I think the website is www.optauto.com or www.opauto.com The last time I saw it, it was about 85.00 for it.
Hope this helps.
Old Dec 29, 2002 | 12:19 AM
Steel's Avatar
I'm your huckleberry..
yeek! that car looks too much like a 300zx to me! RX-7's and 80's (gen?) 300z's are supposed to be ARCH ENEMY'S, not look like each other!
Old Dec 29, 2002 | 01:03 PM
vaughnc's Avatar
knowledge junkie
doens't matter, I was drooling over the car at 7stock
Just like EVERY 70's car has the fastback look, but I still like/want fastback look of the r100, r130, rx-2 coupe, rx-7 sedan, rx-3 coupe stickshift, rx-3 sedan stickshift, rx-3 waggon stickshift, rx-4, rx-5, etc..
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
