View Poll Results: Best Fuel Pump? Price/Quality/Reliability/Performance...
Walbro
27
27.27%
Bosch
12.12%
OEM Supra TT fuel pump
24
24.24%
Nippondenso
27
27.27%
Cosmo
7.07%
others
6.06%
Multiple Choice Poll. Voters: 99. You may not vote on this poll
Help me choose a Fuel Pump
Old Nov 13, 2002 | 10:20 PM
DRAG0NEER's Avatar
My mods:
intake
dp
mp
cb
pfc
IC soon or later
1300 sec injectors going in at the same time
Please vote based on your honest opinion and not what you have. Also, if you can post a link to the vendor w/ the lowest prices, that would be great! Thanks!
Old Nov 13, 2002 | 10:31 PM
ttRx7racer's Avatar
The C-west car used 2 Bosch units and one O.E. pump from a R33 Skyline.
Old Nov 14, 2002 | 12:52 AM
artguy's Avatar
WTB** Very Low Miles 94-95
i wonder why when I tell the the tuners that I have the nippondenso they all smirk and snicker.
everyone running high power uses the expensive pumps...the low end nippondenso is good for around 390 hp...you need one that will support the mods you plan on running.
j
Old Nov 14, 2002 | 12:54 AM
loi's Avatar
loi
go with the walbro, cheap and it work good.
Old Nov 14, 2002 | 02:25 AM
maxcooper's Avatar
WWFSMD
How far do you plan to mod your car? Any of them should be fine for your listed plans.
-Max
Old Nov 14, 2002 | 03:53 AM
DRAG0NEER's Avatar
my twins are at 65k and i know they'll be running for a while. I know I'll have to get another pump when I go single, I pretty much just wanna have one that would efficiently supply fuel while I max out the twins. Do bosch even make one and where can I find it? I'm debating between the walbro, supra, and the bosch. thanks.
Does anyone here have PERSONAL experiences with walbro pumps failing on them?
Old Nov 14, 2002 | 10:49 AM
matty's Avatar
i have read that the walbro is the least powerful of the bunch....and the supra to be the best....when upgrading why limit yourself with something that is only marginally better. i am getting a pump soon too i think the nipendenso that rx7store sells is thew supra one...thats the one i will use.
Old Nov 14, 2002 | 11:24 AM
nocab72's Avatar
03 Cobra Killer
I'm currently using the Nippondenso with a Pineapple Large Streetport & GT35/40 @ 17psi... around 500rwhp according to my traps and Blitz Powermeter. I think I'm at the limits of this pump, although I'm not leaning out at the top of the rpm spectrum (9000rpm for me).
Working on a dual intank pump setup... Does anyone MAKE a dual intake pump setup (Brackets, etc) already?
K
Old Nov 14, 2002 | 11:49 AM
mjw's Avatar
mjw
The Denso/Supra pump will work just fine, those guys are running small singles on their Supras with the stock pump and making close to 500rwhp with it. I have used Walbros on a couple of Supras as well with good results, they flow very well until you get into really high fuel pressures.. I ran a Walbro with a 60-1 @20psi with no problems.
Old Nov 14, 2002 | 01:59 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Go with the Supra pump. Same exact thing as the Walbro 255. But you'll save some money. Best of luck.
Old Nov 14, 2002 | 02:16 PM
Scrub's Avatar
bow leggin'
nocab, your redline is 9000 now??!!
Old Nov 14, 2002 | 02:28 PM
apexkw's Avatar
in slow, out fast!
nippondenso
i am using the nippon denso and it works fine.
Old Nov 14, 2002 | 02:33 PM
nocab72's Avatar
03 Cobra Killer
Rob @ Pineapple said the motor is good for 9k redline daily driven. I modified my PFC tables so I could tune the extra 1000rpm above standard 8000 as well.
Was at the track, had the revlimiter set to 8500, kept hitting it because the car was pulling so strong still...
K
Old Nov 14, 2002 | 02:46 PM
ptrhahn's Avatar
Get the Supra turbo pump. Good for 500 hp (on a supra) and I called a toyota salvage yard and got mine (off a '98) for $95.00 plus shipping. Dave @ KD tested it before installing.... its a direct bolt-in replacement for your stocker.
Old Nov 14, 2002 | 02:52 PM
blackscorpio's Avatar
#1 F0RUM TROLL
In this case size does matter . I would go with the largest fuel pump I could and never worry about it again.
Old Nov 14, 2002 | 03:25 PM
mjw's Avatar
mjw
You're right, size does matter in terms of fuel pump flow.. but going out and buying the huge Apexi fuel pump, or some 1000HP SX pump is ridiculous for his mods and a total waste of $$$.
Old Nov 14, 2002 | 04:05 PM
rxrotary2_7's Avatar
i agree. i am currently running a bit overboard now. i have my tank "sumped" and using the aeromotive A1000 pump. it is a bit more than i was counting on. i am running a single, but still think it *may* be a tad overkill. this pump is like a small tank! i have about $1000 invested in the fuel system. between the pump, custom primary and secondary rails, injectors, guage, FPR, lines and AN fittings...and then changing it twice ontop of all that (dont know what the actual cost of what i am still using is.) has left me .... ummm.... with a lot less cash.
on the bright side, i think i am DONE upgrading my fuel system for a good long time now.
Old Nov 14, 2002 | 09:48 PM
MichRX7's Avatar
Ok, what are you going to sell the Nippo for when you go to a new one? If it's good enough for your car, it's good enough for mine...
Old Nov 14, 2002 | 10:34 PM
zayrx7's Avatar
the mazda zoom zoom store
Not sure if I'm going to go for a single large pump, or a dual setup, like dual Nippo's.
K
Old Nov 15, 2002 | 07:04 AM
GsrSol's Avatar
Z06 powered FD
Honestly,
Why would you go cheap on a fuel pump? Saving $100 might cost you alot more in the end if it fails. Do you want to risk that?
Nippon Denso parts last forever and are known for that. They are stock parts on Hondas, Toyotas and alot more which are very reliable cars. We also know that Toyota did not go cheap/unrealiable on the Supra.
Supra TT ND pump will be the best bet.
Old Nov 15, 2002 | 07:30 AM
matty's Avatar
who sells the supra pump? anyone have the part number?
Old Nov 15, 2002 | 08:51 AM
^What he said .
Chris Ott has told me many times that the pump they sell had been dyno tested on their drag car up to ~500rwhp. I also believe that the pump is an OEM Supra pump. Check out rx7.com fuel upgrades.
Rich
Old Nov 15, 2002 | 11:25 AM
the_glass_man's Avatar
Will u do me a kindness?
Jason sells the Supra Denso Pump.
Old Nov 15, 2002 | 11:31 AM
loi's Avatar
loi
the walbro pump prove to me to made over 450hprwhp. i have them on my 99cobra blown made 445rwhp and now i have it on my single fd. no problem what so ever and it's cheap. around 100 dollar brand new. why anyone want to buy a used pump for the same amount of money?
Old Nov 15, 2002 | 03:09 PM
I have talked to two local Mustang owners who had their Walbro's fail on them at WOT on the highway. Also, when I had installed mine I noticed that it was smalled than the stock pump. The last time KD Rotary had my car, I spoke with Dave about my concerns and he recommended replacing the Walbro with an OEM Supra TT pump. The last thing I want is my fuel pump taking a **** on me at 15 psi at the top of third gear. I've always followed Dave's advice, so I made the swap.
Rich
