I upgraded the Fuel Pump...now running too rich?
This is a follow-up to my last FP post.
I recently swapped my OEM FP for a Denso Supra TT FP(rotoryperformance). Now, now when I am running at WOT above 5000 rpm the car feels like its struggling to rev any higher. The car accelerates fine down low.
My mods are:
Autometer Boost Gauge, 17" Kosei S5R Wheels, Eibach Pro Kit Springs, Tokico illumina 5 way adj. Shocks, 17.5 lb Flywheel(should'a went with the 9.5 lb fw), Custom CAI w/ K&N's, HKS Exhaust, Greddy Turbo Timer, 3" SS Downpipe, M2 Stage III ECU, Home Depot Boost Controller, Home Depot Torque Brace, N-tech Hi-flow cat, Non-Sequential Mod., ASP/M2 Large SMIC, Greddy Elbow, Hawker Drycell mini Battery, 99-spec lip., Denso Fuel Pump, Pettit Front Sway Bar.
To be installed: HKS Twin Power
@12-13psi Boost
___________________________________________
So is my car running too rich due to the increased Fuel flow???? Or is it an ignition/spark problem?
My mods are:
@12-13psi Boost
rich
Yes you're running to rich. Had the same problem in the past. I used the PIM volatge on my PFC to pull out some fuel between 5-6 RPM. The car now pull strong up to redline .
Serge
Serge
Originally posted by jpandes
Serge,
That's what I thought. I hope the HKS twin power helps with this problem.
Damn, I think it's time to 'graduate' to the Power FC!!!
John
Serge,
John
I can't live with my PFC. Great tuning tool.
Serge
You should check your fuel pressure, sometimes when people install this pump there are problems or a leak inside that tank that makes pressure too low. Then you would be running too lean, running too lean can make it hard to rev. I wouldn't *assume* it is too rich. Do a simple fuel pressure test while driving, then you can make a better guess.
Wade
Wade
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
jetlude
Aug 18, 2015 04:53 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
