A/C Questions
Old Oct 9, 2009 | 06:42 AM
nobodymv's Avatar
Slow Lane Perfectionist
FL A/C Questions
I have an '84 GSL-SE that needs a new A/C compressor. I have verified it is the Nippondenso 10P13E.
While pricing them, I can get a remanufactured one for $281.99. THEN I noticed that a Nippondenso 10P13E for an '84 Honda Accord is $248.88 at the same store.
My questions are:
1. If they are BOTH listed as Nippondenso 10P13E, would both bolt into my car? I ask b/c the interchange #'s are different for Car Care Parts, Four Seasons, Everco, and VCCS between the 2 compressors. I am thinking that although they are both Nippondenso 10P13E, the mounting points may be different (?)
2. I know for example, when you replace your clutch master cylinder, you do the slave as well. Since I am am changing the compressor, should I also be doing the condensor, drier, lines, etc?
Thanks in advance for any assistance / knowledge you provide
Old Oct 9, 2009 | 07:19 AM
kutukutu1's Avatar
i just did some research and no the mounting bolts are not the same. i dont think you should change the other things unless they are broken. look at them and determine if they are good or not.
Old Oct 9, 2009 | 09:05 AM
mazdaverx713b's Avatar
Have RX-7, will restore
just an fyi, when replacing any a/c component, make sure you replace the receiver/dryer and have the system properly purged.
Old Oct 11, 2009 | 06:32 PM
chris rx7 gsl-se's Avatar
gsl-se only 13b
you know i just tore out my whole ac out of my 1985 gsl-se dont know if any of this will work in your car but i would sell the stuff for cheep it is just rotting away in my garage
_Tones_
May 25, 2021 05:37 AM
