Injector differences
Old Feb 25, 2008 | 11:26 PM
backroad-junkie's Avatar
Scotty Doesnt Know
How would a s4 TII run if it had high impedance injectors in it? And how would a high impedance/saturated system run with low impedance injectors all of the necessary size. Im just wondering as we put some unkiwn TII injectors in my s4 TII and it runs like trash missing and stumbling all the time when accelerating(or at least trying to). Could it be the type of injectors or just the condition?
Old Feb 25, 2008 | 11:45 PM
SpeedOfLife's Avatar
rotors excite me
This is covered in the FAQ and various threads you could have easily found by searching.
Old Feb 25, 2008 | 11:49 PM
Scotty Doesnt Know
did search, thanks, just wanted to see who would be first to flame...bored
Old Feb 26, 2008 | 09:21 AM
Aaron Cake's Avatar
Engine, Not Motor
S4 TIIs came with both high and low impedance injectors. If the car is older then 87.5, it's probably low. If it's newer, then it's high. You can tell because low impedance cars will have the injector resistors.
Old Feb 26, 2008 | 09:34 AM
pfsantos's Avatar
(blank)
Injector resistor is behind the right headlight assembly, oval plug, five wires used. Ceramic rectangular resistor with a metal bracket around it.
Old Feb 26, 2008 | 12:07 PM
arghx's Avatar
rotorhead
low impedence injectors in a high impedence harness requires resistors (or a different injector driver. FJO makes one, see the single turbo forum). Many say 10 ohm resistors (the most common) are fine, while some others (like me) swear lower ohm resistors improve injector staging, depending on your engine management system. The stock resistor pack in 86-87.5 cars is around 6 ohms I believe.
Old Feb 26, 2008 | 01:06 PM
sunshine's Avatar
Am I correct in saying that if you put a multimeter across an injector, it will spit out its impedence? If so, what impedence would one see across a low and across a high impedece injector?
-a
Old Feb 26, 2008 | 01:19 PM
87 t-66's Avatar
not a drifter
someone please close this thread
Old Feb 26, 2008 | 01:56 PM
t24todd's Avatar
RE_p Rotors
lows are 2.0 -2.8 and highs are between 12-15 estimated...i know highs have to be more than 12 though
Old Feb 26, 2008 | 05:42 PM
HAILERS's Avatar
HAILERS
-a
Yeah. Your just measuring the resistance of the injectors coil.
JPG of a solenoid resistor package located bolted to the fender below the airfilter assy. NOT my car. JPG stolen off the net.
Queppa
Nov 18, 2024 03:47 AM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
