Hole drilled through trunk and gastank?!?!?!
Old Nov 14, 2007 | 12:34 PM
turBRO240's Avatar
Certified Rotorhead
Exclamation Hole drilled through trunk and gastank?!?!?!
WTF?
I noticed when i fill up all the way... gas leaks from the gastank and alittle in the spare tire well. I went under the car, hit the gas tank a few times and i noticed gas squirting out of a hole in the spare tire well.
Someone drilled a hole straight through the spare tire well into the gastank now there is a puddle of gas in the gap between the gastank and the chassis.
Going into the shop on friday to plug up the holes
Anyone have a reason to drill that hole? or was the previous owner just trying to set my car on fire?
Old Nov 14, 2007 | 12:37 PM
JSmith0101's Avatar
Play Well
Hard to drop the tank on FDs?
Old Nov 14, 2007 | 01:01 PM
spandy's Avatar
Patience
Hard to say as people have the craziest ghetto rigged **** in their cars sometimes.
Could of been an amp of speakers of some sort as well.
Old Nov 14, 2007 | 01:03 PM
joe-c's Avatar
YOUR MOM IS MY ADDICTION
Veteran: Navy
**** it put a fuel cell on dat H*E
Old Nov 14, 2007 | 01:05 PM
turBRO240's Avatar
Certified Rotorhead
I would... but im in socal... and i semi-DD it
Old Nov 14, 2007 | 01:14 PM
gracer7-rx7's Avatar
needs more track time
probably someone either relocating their battery or mounting an amp
Old Nov 14, 2007 | 02:02 PM
Prometheus's Avatar
Still got it.
there could have been a problem wih water gathering in the wheel well.
so the dumbass thought they'd drill a hole to leak water.
into the fuel tank...
lol
Thats my thought.
Old Nov 14, 2007 | 03:43 PM
sevensix's Avatar
rotor rotor pow.
picture please
Old Nov 14, 2007 | 05:53 PM
turBRO240's Avatar
Certified Rotorhead
will do...
now i have to ******* pump out a full tank of gas to fix it -__-
Old Nov 14, 2007 | 05:54 PM
turBRO240's Avatar
Certified Rotorhead
And talking to the previous owner.... he said the owner before him had a intensce stereo... so it was probably for amps.
Old Nov 14, 2007 | 06:23 PM
The Driver's Avatar
Diamond Cut Seven
Get some silicon or some heavy duty sealer asap man! 20 gal of 93 is no joke when lit! Seriously what a dumbass, drill = friction, friction = heat!
Old Nov 14, 2007 | 06:24 PM
sevensix's Avatar
rotor rotor pow.
wait if u take a pic pls don't use the flash lol
Old Nov 14, 2007 | 06:47 PM
badddrx7's Avatar
All Spooled Up
You've got to be shitting me !!
Old Nov 14, 2007 | 09:05 PM
Busted7's Avatar
Will work for horsepower
No need to pump out the tank it has a drain plug on the bottom!
cto_2
19
May 8, 2018 08:15 AM
