Lsd?
Old Dec 19, 2006 | 06:42 PM
jvallo7's Avatar
Lsd?
how can i tell i have a LSD?
Old Dec 19, 2006 | 06:53 PM
Dak's Avatar
Dak
Information Regurgitator
Jack the rear of the car up off the ground. Make sure both wheels are off the ground. Put the gearbox in neutral.Spin a wheel. if the other one turns the same direction it is LSD. If the other one turns the opposite direction or not at all you have an open diff. What make and trim level is it? Some trim levels never had LSD and I think all factory Turbo cars(TII's) came with LSD. Look in the FAQ's I think it's in there which did,did not and might have.
Old Dec 19, 2006 | 07:38 PM
mikaz's Avatar
The Extremist
quoted directly from the FAQ, which you should have read allready.
Did my 2nd Gen RX-7 come with a Limited Slip Differential?
Only the following USA model 2nd gen RX-7s had a LSD from the factory:
86-88 GXL
87-91 T2
88 GTU
89-90 GTUs (however not the 89-90 GTU)
It is also rumored that a few rare 91 coupes with both the A (upgraded the interior trim, added a power sunroof, tilt steering wheel, cruise control, and 4 piston front disc brakes and vented single piston rear brakes) and the B package (leather seating, a CD player, and rear cargo cover) came with a LSD, but you should note that Mazda denies that any FC other than the T2 came with a LSD in 91). You can also tell by looking at the differential as there will be a LSD tag on S4 cars with a LSD.
[/thread]
Old Dec 19, 2006 | 08:16 PM
hurleysurf24's Avatar
wtf rotary wtf
if your eyes dont dialate ... thats the easiest method
Old Dec 19, 2006 | 08:17 PM
Dak's Avatar
Dak
Note the '89-91 cars didn't have the tag on the diff but if it's not a TII or a GTUs it would be very rare to have one.
Josh83rx7
Oct 2, 2015 07:13 AM
Josh83rx7
Sep 24, 2015 11:47 AM
