The FD Restoration - $$$$ Damnit
#331
Never give up!
Originally Posted by cartapex
Ummmm Adam...which parts are these, and where do they go? They don't seem to go on your car.....oh yeahhhhhhhh. Nevermind. Not related. Glad you stuck with the original idea. (Bought my stage 3 today....hehehehehehe I will crush you)
#333
Searching for 10th's
#336
I had to go to Seattle Friday night and fix my truck after my dad got into a fender bender earlier last week. He needed it somewhat fixed before he left for Colorado next Tuesday. I had to use a giant waste bin pickup point, 7000 lbf tow strap and the trucks own motorized power to bend the bumper out of the wheel well. Then used crowbars and a mallet for the rest. Gorilla taped the headlight since all the plastic clips broke, all in all not a bad temporary fix.
#341
Well, two weeks in a row now I've been mostly working on other people's cars. Spent most of the weekend getting Cartapex's car running mostly right with street tuning and fixing small issues, like a loose oil return fitting off of the turbo. The tune is pretty close, just needs to be dyno tuned now.
However, I was able to start on the modification of my hood. Need to cut out the support structure, form the lip and then weld on a new support structure. I also got a hood pin assembly and will be putting that in too.
#343
Alright, so I started the process of forming the front lip and made a template of the curvature I need to follow for the support structure. Will be making a support frame before I finish the top surface. Need to remove the exposed support frame under the new lip now.
