Exhaust system tests ?
Old Jun 4, 2004 | 09:28 PM
J.S.J's Avatar
I checked my back pressure as I have been doing for 20 years and the system checked good. I hold the rpm at 3k and it should read under 1.5 lbs. I found with the turbo system that formula does not work well. I drove my fd with a gage in the 02 sensor port and pushed a midrange ammount of boost and the gage read about 4 psi. I removed the cat and it was busted up inside and restricted. I am thinking the small size of the engine (CC) and a large volume exhaust the cat will check out good using the typical 3k test. Has anyone tested their systems and have some more numbers to share.
Old Jun 4, 2004 | 10:53 PM
FDjunkie's Avatar
I've been watching for posts on this same subject. Here's a thread on my test results.
https://www.rx7club.com/showthread.p...t=backpressure
Th0m4s
Feb 26, 2019 02:04 AM
efini7
Test Area 51
Sep 4, 2015 02:59 AM
GrossPolluter
Aug 22, 2015 11:23 PM
