Microtech s4/5/6 injector plugs and weather proof connectors
Old May 10, 2004 | 11:39 PM
10sec rx7's Avatar
Guys,
i noticed a few are after injectors plugs and weather proof connectors, i can get these brand new, all connectors are un assembled and come with pins and seals
s4 square type injectors $8au
s5/6 oval type in high or low keyway $17au
rubber boot for back of square plug $8au
and weather proof connectors in the following
1 pin $10au
2 pin $10au
3 pin $15au
4 pin flat $19au
4 pin square $25au
shipping for the connectors is not very much and would take around a week and a half to arrive on your door step,
payments to be made through paypal
Dale
Old May 10, 2004 | 11:42 PM
silverrotor's Avatar
The problem has always been sourcing out s5 Harness Plugs. So they are $17aus each? For the set? Time to do a Can > Aus currency conversion...
Old May 10, 2004 | 11:45 PM
10sec rx7's Avatar
they are $17 each connector, $68au for a set of 4,
for a s5 you will need 4x high key way denso plugs, 1x square bosch plug (for water temp), 3 way weather proof for tps, 4way square for CAS,
CAN - AUD is pretty much 1:1
shipping will be about 10-15au
Dale
The Shaolin
Sep 14, 2015 07:50 PM
86rxNa
Aug 11, 2015 11:51 AM
