99+ Bumper under pan
Old Mar 31, 2005 | 03:15 PM
PureMdMa's Avatar
1 of 203 94 White PEP's
I am in need of a 99+ Bumper underpan/underbelly does anyone here know where I can get one?
Thanx
Jeremy
Old Mar 31, 2005 | 03:26 PM
Tim Benton's Avatar
FD title holder since 94
does the 93-95 not fit with a 99 nose?
Tim
Old Mar 31, 2005 | 03:27 PM
scotty305's Avatar
~17 MPG
www.mazdamotorsports.com , you need to be a member (submit 2 race results per year).
Part No.
F140-56-1B0A
Description
COVER, UNDER - FRONT
Notes
Front splash tray, under engine connecting to front bumper. Should be used when installing '99 Front Bumper to earlier models.
-s-
Old Mar 31, 2005 | 03:35 PM
PureMdMa's Avatar
Tim, no it doesnt from what ive read and heard.
I dont have race result so cant purchase from mazdamotorsports although I am a member, they have recently gotten strickt from what it looks like.
Here is a picture of the 93-95 one next to the 99-02 one.
Old Mar 31, 2005 | 03:40 PM
Tim Benton's Avatar
how much is it? Looks like there's another piece I need to get the 99 to fit the car.
Tim
Old Mar 31, 2005 | 03:43 PM
G's 3rd Gen's Avatar
got mine to fit alright....
Old Mar 31, 2005 | 03:49 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Even the 99 underbelly needs little cutting.
Old Mar 31, 2005 | 03:51 PM
ptrhahn's Avatar
It fits fine, but you should remove the little sub tray on top.
Old Mar 31, 2005 | 04:12 PM
maybe you can order 2 99+ underbelly/underpans...I need one to. I am not a member of mazdamotorsports.
let me get a hookup.
thanks
Old Mar 31, 2005 | 04:26 PM
PureMdMa's Avatar
Yeah looks like if you just remove the smaller piece in the middle that its pretty much the same, I think ours will fit if we try hard enough. But I think the 99 one is only like $100-$150 and mine is not in the best shape to begin with.
Old Mar 31, 2005 | 04:41 PM
scotty305's Avatar
~17 MPG
PureMdMa , the other way to purchase from Mazda Motorsports is if you're still building a car, you can send them your SCCA membership number and be able to purchase parts without sending race results. You might also try these part numbers with Ray Crowe at Malloy, they might be available to any U.S. dealer:
The undertray is about $100:
This should be the complete kit:
F138-50-031A FRONT BUMPER COVER Notes: From Japanese Model 99-00 RX-7. Larger air intakes and lights than U.S. spec bumper. Requires '99 bumper reinforcement, and combination lamps.
F138-50-070B REINFORCEMENT, BUMPER Notes: '99 Japanese RX-7 front bumper reinforcement. For use with F138-50-031A front bumper cover.
F140-56-1B0A COVER, UNDER - FRONT
F138-50-A21 AIR GUIDE, FRONT BUMPER Notes: From Japanese Model 99-00 RX-7. Recommended when ordering 99-00 style front bumper assembly.
F138-51-9K1B C SKIRT (R), FRONT AIR DAM
F138-51-9L1B C SKIRT (L), FRONT AIR DAM Notes: Left half of front lower air dam/lip spoiler. Larger and more aggressive than R1 spoiler from U.S. models. This is from the '99 RX-7 but can be made to fit earlier models. This is only one half of spoiler. Use with other side.
F138-43-64XB DUCT (L) , BRAKE AIR COOLING
F138-43-63XB DUCT (R) , BRAKE AIR COOLING Notes: Left brake cooling duct required when installing '99 RX-7 front bumper to earlier years. Design eliminates oil cooler ducting.
F138-51-731 EMBLEM, WINGED M - FRONT Notes: New Winged-M logo for nose of car. From '99 RX-7
F138-51-070B LAMP (L), FRONT COMBINATION
F138-51-060B LAMP (R), FRONT COMBINATION Notes: Right front turn signal assembly. Fits openings in '99 Japanese RX-7 front bumper.
F138-51-680B LAMP (R), FRONT FOG
F138-51-690B LAMP (L), FRONT FOG Notes: Left front fog lamp from '99 RX-7. Round
-s-
Old Mar 31, 2005 | 04:43 PM
7racer's Avatar
here is the 99 spec airguide
https://www.rx7club.com/forum/showth...light=airguide
Old Mar 31, 2005 | 04:56 PM
PureMdMa's Avatar
Yeah i have that piece already hehe. Ill check with ray and see if he can get this or not.
L8r
Old Mar 31, 2005 | 05:03 PM
Tim Benton's Avatar
Jeremy, let us know if he can.
Thanks,
Tim
Old Aug 2, 2005 | 10:22 PM
SRA-FD3S's Avatar
update can ray get the parts!!!!!!!1
Old Aug 2, 2005 | 10:55 PM
afterburn27's Avatar
Lets Go Hokies!
unfortunately he can't get 99 spec parts.
Mazdamotorsports sells everything, but the undertray is on backorder with no ETA from Mazda.
Old Aug 2, 2005 | 11:48 PM
Madmax670's Avatar
rotors + turbos = bliss
What is the purpose of this component? I have it off of my car right now
Old Aug 2, 2005 | 11:51 PM
Lets Go Hokies!
It forces air through the radiator, so I would suggest that you put yours back on. Some people have run their engines dangerously hot because they were missing this piece.
Old Aug 2, 2005 | 11:52 PM
Madmax670's Avatar
My water temps never see over 92 C, even on 100 degree days, in that case, should I still put it on?
Old Aug 2, 2005 | 11:55 PM
Lets Go Hokies!
As long as you are watching your temps and they stay cool then I guess you should be fine. If it were me I would put it back on anyway, but its not my car.
Old Aug 2, 2005 | 11:58 PM
Madmax670's Avatar
Is there any other reason to have it on, will it make any kind of pressure spots or something?
Old Aug 3, 2005 | 01:11 AM
scotty305's Avatar
~17 MPG
Think of it this way: Mazda's engineers spent a lot of time making our car lightweight and aerodynamic. The front undertray weighs very little, but it's aerodynamically significant. I can't think of any reason to remove it aside from being a cheapskate.
Here are three good reasons for leaving it on:
1. Cooling function: forces air through the radiator, preventing overheating (as mentioned above).
2. Aero effects: helps create a smooth underbody, which will cause less drag as speeds increase.
3. Protection: keeps debris and water out of the engine compartment, away from the steering boots, etc...
Can you name three good reasons for leaving it off?
-s-
Old Aug 3, 2005 | 07:25 AM
Section8's Avatar
Just a side note about MazdaMotorsports membership, you don't have to be a racer to get in, you can do two autocross events and qualify.
Old Aug 3, 2005 | 07:38 AM
ptrhahn's Avatar
You need AN undertray, but basically all this thing is is the 93-95 tray with the subtray removed where it used to meet w/ the 93 nose. It'll take you about 10 minutes to dremel it off. Make sure you leave the part with the rubber bumper that seals against the bottom of the radiator.
Old Aug 3, 2005 | 08:12 AM
Julian's Avatar
I put a '99 under tray and '99 lip on a 93-95 bumper, the tray is interchangeable and bolts right up, which is amazing considering the amount of drilling and cutting I had to due for the lip?? The shape out on front wings is a little different, but then that is to fit '99 brake ducts which I like better besides fitting up to lip. The inner radiator "ramp" on 93-95 undertray can be removed, it is suppose to provide a smooth transition from the nose to
the radiator. but if you open up the nose with '99 bumper or shark mod on stock nose, it gets in the way of airflow. My cost was just under $100 from Mazda Motorsports, needed to replace my original one anyway's. Do not leave the tray off. It is the single most important piece to force air through the radiator not under the car, It protects radiator, hoses, oil line and fan belts from stones and other road debris, it is a major aero feature not just drag reduction but stability.
