if you were in market for new turbo
Old May 13, 2003 | 10:53 PM
rx7racer11's Avatar
basically im going to be getting a engine built here with 2mm seals, and a small streetport. and im wanting to go single.. my twins have cause me more headaches than grins.. so time to simplify im not after the fastest 7 i just want a good single turbo setup what would be the best one for just a street application..
Old May 13, 2003 | 11:00 PM
RICE RACING's Avatar
Not in any particular order.
To4e
To4s
Gt35/40
RX6
Any of the above will give you what you want, do a search under these part # and you will find heaps of data, more than you can handle, but take your time and do some reading
Old May 14, 2003 | 12:29 AM
rx7racer11's Avatar
if it came down between the gt35/40
or a t-78 which would you buy., for streetablitly less lag
Old May 14, 2003 | 12:41 AM
Badog's Avatar
GT-35/40, hands down. The T78 starts to come on big at 5800RPM ish. Meanwhile the GT-35/40 has pulled 2 cars away already! Now, if you have a Pineapple buillt that can handle higher RPM....that T78 will pull kick **** up to redline! It might make up some of the lead....but which car would you want to be in?
Old May 14, 2003 | 12:45 AM
rx7racer11's Avatar
turbo lag is a drag.... any thoughts on xs enginerring t04s looks like a decent kit with everything in it for good cost.. im sure the gt35/40 would destroy it though
Old May 14, 2003 | 12:55 AM
Badog's Avatar
I think it spools a tad quicker than the GT-35/40, and tops out quicker, but it's a kick to drive around. On a solid engine...it can still put down some rubber! I tuned one that was a dream. I would consider it if it weren't for certain friends that I have to keep up with
Old May 14, 2003 | 12:56 AM
Badog's Avatar
Since you're in that same state as Rob @ Pineapple, you should call him and get a quote. On that foundation, good things can be built!
Old May 14, 2003 | 01:34 AM
88fc3sw/HX83's Avatar
I'm getting a tranny built by him to go with his great motor (they should go good together)
Old May 14, 2003 | 04:44 PM
rx7racer11's Avatar
rob is going to be building my motor.. im getting a small streetport. and probably some porting of oil and coolant passages.. im just looking for a decent single turbo to put down decent power without costing me a arm and a leg.
Old May 14, 2003 | 06:02 PM
93redFD's Avatar
what do you mean the 35/40 will already pulled 2 cars away? I dont think so 1, maybe if it was from dead stop or on a road track. But on the street I dont think so.im not hating or anything just expressing my feeling about it. there both very nice turbos though.
Old May 15, 2003 | 04:11 PM
TurboFD's Avatar
I would think RX6 considering it has such good spool up.
Old May 15, 2003 | 11:18 PM
rx7racer11's Avatar
t04e or t04s whats the difference here besides about $400 what are some advantages disadvantges to each turbo.. thanks!
Old May 18, 2003 | 10:03 PM
Badog's Avatar
Great spool-up on a stock engine. I would not hesitate for stock engine and target of only 400ish RWHP. Would not be unhappy with this combination on a (round) track car.
But if you're engine is breathing free, get something with more lungs like a T04s, or for more potential, GT-35/40!
Old May 18, 2003 | 10:17 PM
Jason's Avatar
The one
The RX6 is a complete ripoff since APexi raised their pricing on that kit. Most places sell it for $4k. Go with a GT35/40 or the XS T04S or T04E. You get better bang for the buck.
Jason
www.rx7store.net
Old May 18, 2003 | 10:24 PM
Resource's Avatar
Jason is right. Rx6 is way too expensive considering that the t04s spools just as fast and is capable of more hp and is less expensive.
