Headlights
Old Jan 28, 2002 | 07:26 PM
Blackrx71's Avatar
Headlights
I saw a headlight conversion for sale on some site. But can't seem to find it now. Will somebody help me please. I am going nuts trying to find them. I think somebody on the FORUM had them for sale.
Old Jan 28, 2002 | 07:41 PM
RotorMotorDriver's Avatar
Seven Is Coming
umm...what kind of headlight conversion? i know of a website that has sealed beam conversions (very cool) but there really pricey...anyway i hope this helps some... Cool Bulbs
~T.J.
Old Jan 28, 2002 | 09:43 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
http://www.geocities.com/mzd_rx7s/Headlights.html ????????
Old Jan 28, 2002 | 11:00 PM
cletus's Avatar
What I did was put in a pair of E-code (european) Hella lenses that were actually for a miata (still a 7" round light). They are not sealed beams anymore but use H4 bulbs instead. I haven't looked into what different types of bulbs you could be using (like fake xenon or whatever), but obviously you could pick any wattage you wanted if your wires/altenator can handle it. I didn't step up the wattage on the bulbs. There is definitely an increase in light. Also the light is focused better with very distinct cut offs (I also have a pair of e-code projectors on my Audi and had the same result with the distinct cut off). I'm happy with the lighting now and the added bonus is if one burns out, you don't have to replace the whole thing, just the bulb. The whole setup including bulbs was $90 from www.rspeed.net
Just some food for thought if you care.
Old Jan 29, 2002 | 03:54 PM
smnc's Avatar
EliteHardcoreCannuckSquad
I've said it before, and I'll say it again.
BEFORE YOU UPGRADE YOUR HEADLIGHTS, CONTACT DANIEL STERN.
http://lighting.mbz.org/
Good prices, and the best service and quality. He knows EVERYTHING about headlights.
I actually have ordered a set of E-Code 7" CIBIE's.
Originaly sent by Daniel Stern (dastern@vrx.net)
Now, 7" round headlamps:
Several companies make 7" (large single round, sealed beam size type 2D1) E-code headlamps. First off, it's important to use CAR headlamps, not the motorcycle ones you sometimes find from Bosch, IPF or CPI. These are easily identifiable (they say "MOTORCYCLE" on the lens) and the beam pattern is not at all well suited to use on a double-track vehicle with low-mounted headlamps. In car units, the most widely marketed in the USA is the Hella 70476, standard H4 European-spec headlamp. (You'd also find the 70477, US DOT "Vision Plus" headlamp, which we call the "Vision Minus" 'cause...well, it's got a replaceable bulb, but it's just not that much better than a sealbeam as far as beam pattern goes, and it tends to collect water because of a badly-done drain design.) But as I was saying, the 70476 is around. I don't use it on my cars that take the single large
(7") rounds; I use Cibies. Why?
Beam patterns are better (wider, longer-reaching) on low and high beam with Cibies. The main difference, though, is that 7" round and 200mm rectangular Hellas have an irritating beam separation problem. Set the low beams where they belong, and the high beams are up in the trees without enough on-road light. Pull the high beams down where they can be useful, and the low beams are down on the bumper. I exaggerate for illustration, but the effect is to make you try to find a compromise setting where both beams are kinda OK. The Cibies do not have this problem; when the lows are correctly aimed, the highs are correctly aimed. Some folks don't find the beam separation as much of a problem as some other folks--and a lot of people who have only ever used two kinds of headlamps (Hellas and sealed beams) will swear that Hellas are the cat's pajamas. It's certainly true that Hellas are a big improvement over
"sealed bum" originals, but Cibies are just better. All Cibie 7" round
headlamps have convex (domed) lenses. Clear Lens Classic lamps have highly convex (highly domed) lenses and are generally for use in pre-1972 cars that must look "period correct", also in hot rods where styling is a prime concern, etc.
Now that we've fixed the beam pattern problem, let's talk about bulbs. Stock wattage is 60/55 (high/low). My "normal" bulbs are German-made high-efficiency 60/55W bulbs; with these, you can just remove the sealbeams, install the Cibies, aim and go with no NEED (though it's always a good idea) for uprating the wiring. Now, the E-code beam pattern, with its sharp cutoff which nullifies glare for oncoming traffic, can support higher-output bulbs without (a) glaring oncoming traffic or (b) creating impossible backdazzle for you in bad weather. Note that it is a VERY poor idea to put overwattage bulbs in with the stock headlamp wiring, which is meant for stock wattage ONLY. We see a lot of car-be-cue type messes when people try to do this. The relays/sockets/fuseholders package to do-up the wiring properly contains all heavy-duty components (dual-output 40A relays, terminal blocks, brackets, terminals, fused fuseholders and headlamp sockets) to accept heavy-gauge wire; supply your own wire from the local economy in your choice of color and length. View and print my "how-to" page at http://lighting.mbz.org/tech/how_to/relays for full text and color diagrams of how to do this. Now that we have good wiring, we can go to town on bulb wattage. NOTE, if you have a passenger car or other vehicle with low-mounted headlamps (lamps below the level of most passenger car drivers' eyes when seated at the wheel) you can increase both low and high beam power without causing undue glare. If yours is a truck or SUV or other vehicle with high-mounted headlamps, you will want to keep the low beams civilized to avoid dazzling other road users. "Other road users" include cops, so use your head! 100/55W bulbs can be furnished to keep the low beams civilized and still punch the next county with the high beams. I do not handle the 3rd-world bulbs you can find in the pages of JC Whitney and in lots of other places. I carry only German-made (Osram, Philips, Narva) bulbs. My policy of selling ONLY items I would use voluntarily on my own cars extends down to bulbs!
How about city lights? What is a city light? It's a European-type parking lamp, a small 5W bulb sticks through a grommet in the lamp's reflector into the lamp itself. Ground one of its wires, and run the other of its wires to the parking lamp feed. The city light illuminates the whole headlamp in a "pilot light" fashion; this makes for large-area parking lamps that WORK, and if a headlamp bulb ever burns out, oncoming traffic still sees you as a double-track vehicle. If you use the city lights to REPLACE the dim amber parking lamps common on US vehicles (which you should not do if your '68 or later American-spec vehicle does not use one bulb to handle front parking lamp and front sidemarker lamp duty) the turn signals now go "BRIGHT-off-BRIGHT-off" instead of "bright-dim-bright-dim" when the lights are on. City lights are especially useful if you have fog lamps. On foggy days, you can put on the city lights which will show other drivers exactly where your car is, and switch on the fog lamps so you can see. Note that city lights are a legal form of parking lamp in the USA. Also note that city lights aren't used on vehicles with flip-door (hideaway) headlamps.
Optional: thin-shell polyurethane impact guards to prevent the lamps being rock damaged or "sandblasted" in normal daily use. For use only on vehicles NOT equipped with hide-away (flip-up/flip-down) headlamps.
Prices at http://lighting.mbz.org/prices
Carefully pack and ship two lamps with whatever accessories you wish, $19
ORDERING INSTRUCTIONS
Please indicate:
The quantity of each item you wish
The type of shipping you wish
(UPS trackable ground shipping is standard; all UPS service levels are
available)
The address to which you want the items shipped (if different from billing
address)
Whether the UPS driver has permission to leave the parcel at your doorstep if you are not available to accept it in person.
VIA PHONE:
303-285-3482 x4983
VIA E-MAIL:
dastern@vrx.net
VIA FAX:
303-285-3482 x4983
Whatever method you use, the following information is required in order to process a credit card order:
Card type
Card number
Expiry date
Your name as it appears on the card
Billing address
Billing phone number
Please don't forget to include a note (such as a printout of our e-mail) stating exactly which items you are ordering, and where you wish them sent.
I look forward to hearing from you.
DS
Old Jan 29, 2002 | 03:57 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
like this?
http://cgi.ebay.com/ebaymotors/aw-cg...item=601164383
Old Jan 29, 2002 | 04:14 PM
There is a forum member who has a web site makeing rx7 custom
parts,clear lens,white face guage overlays,and some other stuff too.
go to J&S graphics.or in the 1st gen photo gallery,or members dir.
see jose reyes,and click on website,in the site at the bottom of a page
is a photo of pop up head lights,,click that link to go to the head light
pages,,the lights look like the lights on badassrx7's car,,4 round lites.
theres a small plug for you jose,,
Old Jan 29, 2002 | 04:15 PM
smnc's Avatar
Originally posted by rx7gslse
like this?
LMAO!!! Hell NO! Those are crappy-*** DOT spec lights, not European
E-Code. It's kinda funny that it says HID and Euro in the Title, but it's neither.
And the HID and "Super-White" Crap that coolbulbs.com sells isn't any better. Read the info at Dan Stern's site.
It's also funny that the car they label as "GOOD" is glaring right into the camera. That's exactly what you DON'T want (unless you wanna **** off everyone on the road)
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
