How to put an aluminum gas cap and where to buy?
Old Aug 20, 2001 | 02:49 AM
EfinireFD3S's Avatar
Question How to put an aluminum gas cap and where to buy?
I was thinking about getting an aluminum gas cap for my fd3s but I don't have much info on where to buy it or how to put on. Any of you guys know the web site to buy one and how you install it???
Old Aug 23, 2001 | 12:19 AM
djantlive's Avatar
I think that would look too ricy on a FD. I know Miata has a Mazda alum piece that looks good. Don't think it'll work for a FD though since the cap shape is different.
Old Aug 23, 2001 | 12:53 AM
HedgeHog's Avatar
Rotary Poseur
I kinda like it myself....here's 2 different installs (not motorcycle caps).
Using Audi TT gas cap
Using new Eclipse gas cap
Old Sep 4, 2001 | 05:47 AM
Viper jr's Avatar
The Audi TT is the way to go, its just a pity that the damn thing costs 400 or so.
Old Sep 4, 2001 | 02:44 PM
0piston's Avatar
You can also use one of the Yamaha motorcycle's 99'yzf or something like that. Just double check with fittings.
Old Sep 5, 2001 | 12:44 AM
Zoomspeed's Avatar
How did you put it on?
Old Sep 5, 2001 | 01:21 AM
HADNSE's Avatar
Sparco makes a flip lid too in aluminum or black and funnels. Make sure it comes with the unleaded nozzle restrictor or you will fall a smog check, BTDT.
Old Sep 7, 2001 | 04:39 AM
AARotary's Avatar
I have the Sparco racing gas cap
The cap itself is a bit smaller than the stock cap because my car is getting a paint job and bodywork it is also a good time to put it on. It is alot of custom work to put it on and the guy at the bodyshop have to custom some metal pieces to hook it up to the gas tank. The end result was good and the gas cap looks like factory and it is also have that polish look.
Old Sep 17, 2001 | 11:27 PM
Node's Avatar
http://airtech-streamlining.com/miscairtech/fuel.html
enjoy. These things look damn good on the upper side of the wheel well bend thingamajig, like on the Type 15th.
I saw a ricer that had a taillight that folded out with the gascap inside. Was pimptastical
I think it was on autobuzz, maybe on hot import nights but im thinking auto buzz. I'll get it later if I can find the pic again
Old Sep 18, 2001 | 12:00 AM
95R2-89TII Ground Zero's Avatar
Banned
I like the way those gas caps look pretty good on 7's. The hardest part is the actual sizing for the new mar glass or bondo that has to be installed to incorporate the new cap. Good luck.
Old Sep 20, 2001 | 12:10 PM
Zoomspeed's Avatar
Are there any that don't require bondo or repainting to put on?
Old Sep 20, 2001 | 06:05 PM
AARotary's Avatar
Here is the Sparco fuel cap but you have to do custom body work
to get it on right.
Old Sep 20, 2001 | 06:35 PM
Viper jr's Avatar
to get it on right.
Goodridge has one identical to that Sparco - available with or without a name on it. Would be nice to find a bolt in replacement without the cost of the Audi TT's tho.
mazdaverx713b
48
Apr 21, 2016 06:45 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
