New to Rotary stuff, questions.
Alright, I have no idea about the rotary's ( like most people
) but I am picking one up this weekend, its an '86 5spd, n/a. The engine is flooded, but I am pretty sure I can get it to start if thats the case. What I would like information on is:
1. What is the common problems or basic tune up stuff to buy? For instance on a 302, its best to get wires, distributor cap, plugs, set the timing etc. . . when you buy one used.
2. What's the difference between the n/a motor and the turbo'd motor? ( besides the tubro
3. Is $250 a good price for this car, it needs new carpet and seats, but thats not a big deal.
) but I am picking one up this weekend, its an '86 5spd, n/a. The engine is flooded, but I am pretty sure I can get it to start if thats the case. What I would like information on is:1. What is the common problems or basic tune up stuff to buy? For instance on a 302, its best to get wires, distributor cap, plugs, set the timing etc. . . when you buy one used.
)3. Is $250 a good price for this car, it needs new carpet and seats, but thats not a big deal.
1. same basic maintenance change ALL fluids. new plugs wires etc. only thing is make sure and get a compression test that's the only major issue.
2.differences, from what i know (not much about turbo models) the turbo is the only real difference. that and they are not as long lasting as the n/a due to extra stress on the motor and crappy drivers that mod them w/out the proper knowledge or safety
3. 250 is an outstanding deal assuming that the compressions good on both rotors.
james
james
Thanks james, can I do a compression test just like I would on a regular engine
, or is there something special involved. Is there a range compression wise I should be looking for, too?
AbecX, as I was told, welcome to the rotory hell.....
We just got into them as well, and are in the process of getting our 88 up and running right. As for the compression test, you cannot do it the same as a piston motor. The rotory has three "compression" chambers per revolution, while the piston motor only has one. Therefor you must use a compression gage that DOES NOT hold the pressure (basically remove the check valve for the gage). Here is how we did ours:
1. remove the two upper spark plugs from the engine (these are the "trailing" plugs, not the "lead" plugs).
2. Unplug the crank sensor and the fuel pump.
3. install the gage in trailing plug 1 (front, top plug hole).
4. Have someone hold the throttle wide open and crank the engine for several revolutions. The gage will jump three times per revolution. These bounces should be about even. If only one "bounce" is down, it indicates a bad side seal, if two low, followed by one high then a bad apex seal could be at fault.
5. Do the same for trailing plug 2 (back top plug).
Our compression for a 13B motor is suppose to be at 85 PSI with no more than 21 psi difference between chambers.
I hope this helps....
you will need a special tester or a modified piston tester. do a search for how to modify the compression tester i think it's a newer post. the range of compression is it has to be over 85 the best is 110-115. if it's lower compression than 85 you might be able to bring some back with the atf trick(do a search for this too)i had an 87 that had 70 on the rear rotor when i bought it did the atf trick and compression came back. oh and look up the fsm on fc3s.org for compression procedure because there is not a TDC i'M SURE.
james
james
I'd say that $250 is a great price for the car if the engine is just flooded. Especially if the rest of it is in good shape.
If the engine is flooded, try pulling the EGI fuse and cranking it a time or two. Replace the fuse and see if the car starts up now.
Other than that, if the engine isn't completely dead, check the compression and if all is well, go for it.
Trending Topics
Re: New to Rotary stuff, questions.
http://fc3s.org/
I like the Fumoto oil drain valve (the plain F106), but it's only an accessory, and is not required.
http://www.fumotovalve.com/
2) The main differences between the NA and TII motors are the porting and compression ratio.
3) Yes, $250 is a good deal, even if the engine is toast.
You can learn more at these sites:
http://www.aaroncake.net/RX-7/
http://fc3s-pro.com/sitemap.html
http://www.monito.com/wankel/wankel.html
http://2ndgenrx7.freeservers.com/
http://www.iluvmyrx7.com/
http://www.mazdatrix.com/
What if the engine is vapor locked? Just add some oil in the intake? Or can they even be vapor locked?
turbo-minivan
69
Feb 4, 2016 12:29 AM
