question about 5th and 6th ports
Old Apr 24, 2003 | 11:29 AM
IDx
what controlls the 5th and 6th ports? i know its backpressure off the exhaust but how exactly does it work? and how do you keep the ports functioning after getting header put in place with no cats.
Old Apr 24, 2003 | 11:32 AM
jcina7's Avatar
86-88 exaust backpressure.
89-92 air pump and acv activated.
from both those sources of pressure, pressure goes to the brown and white solonids. when activated, the pressure is then routed to 6 port actuater diaphrams, and viola. they open.
Old Apr 24, 2003 | 01:00 PM
J-Rat's Avatar
Alcohol Fueled!
Not quite, but close.
Only the Series 5 has solenoids that control the 6-port actuators. On the series 4, the exhaust backpressure goes directly to the 6-port actuators.
Jarrett
Old Apr 24, 2003 | 05:31 PM
NZConvertible's Avatar
I'm a boost creep...
They're called auxillary ports, not 5th and 6th ports.
Old Apr 24, 2003 | 05:33 PM
Bebesito21's Avatar
How many intake ports does the NA 13b have? 6. Which ones are the auxilary? The 5th and 6th ones.
Old Apr 24, 2003 | 05:34 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
5th and 6th
Is our slang leave it alone. They are technically the 5th and 6th ports in a 6 port engine.
Old Apr 24, 2003 | 07:21 PM
Have you ever seen "5th and 6th ports" written in the FSM? Didn't think so...
It doesn't sound like slang, it just sounds like you don't know what you're talking about.
Old Apr 24, 2003 | 07:41 PM
RyosukeTakahashi's Avatar
whoa whoa whoa take it easy man.. no need to get upset about the name
Old Apr 24, 2003 | 07:46 PM
1987RX7guy's Avatar
Look dude you understude what I said. I don't care if it is not in the FSM. Just about everyone calles them that here. Who gives a **** anyways this guy does not need you screwing up his thread with useless garbage.
To the thread started: Auxilary ports and 5th and 6th ports are the same thing. We call them 5th and 6th here because the N/a engines have 6 ports the 5th and 6th are just that the fith and sixth ports on a six port engine. We are using logic.
Old Apr 24, 2003 | 07:47 PM
1987RX7guy's Avatar
Re: question about 5th and 6th ports
Oh and did you notice he used that term and not "auxilary" I think using his terms will make it easier for him to understand an explenation. You don't have to be DICK about it.
Old Apr 24, 2003 | 07:49 PM
J-Rat's Avatar
Alcohol Fueled!
Woah!!!
Bad attitude man!
Aux-ports, 6-ports, 5th and 6th ports...Whatever.
Its all the same thing. Same as stabilizer bars, sway bars, and ANTI-sway bars.
Sheesh, you people need a standing prescription to some valium...
Jarrett
*edit* Hey 87RX7GUY, take NZC with a grain of salt, he is only trying to help.
Old Apr 24, 2003 | 08:00 PM
IDx
thanks for all the response.. i was just curious how i would deal with those evil ports once i remove my air pump and acv when i get my headers.. any suggestions?
Old Apr 24, 2003 | 08:04 PM
J-Rat's Avatar
Alcohol Fueled!
Since you have an 86, I wouldnt do anything. They should still work if your cat is still installed.
Jarrett
Old Apr 24, 2003 | 08:07 PM
IDx
im going to be removing all of that i live in florida.. no emissions.. muahah im going to run a rb header straight through
Old Apr 24, 2003 | 08:11 PM
1987RX7guy's Avatar
get a pre-silencer man. you still need some backpressure. Get the RB one with the SAP fitting on it
Old Apr 24, 2003 | 08:13 PM
selanne8's Avatar
be prepared for a LOUD car ... like that's a bad thing...heheheheh
john
Old Apr 24, 2003 | 08:21 PM
I have that setup and its not "too loud" by my standards.
Old Apr 24, 2003 | 08:25 PM
J-Rat's Avatar
Alcohol Fueled!
WTF is SAP?
Old Apr 24, 2003 | 08:36 PM
1987RX7guy's Avatar
Split Air Tube
Old Apr 24, 2003 | 08:37 PM
Notice how some of the younger members resort to flaming when they get upset? Anyway...
The auxillary ports are not evil, they are your friends, and the reason why 6-port NA engines make a lot more power than earlier 4-port ones.
The actuators require very little pressure to operate (2.1psi to fully open), and if the sleeves can turn freely in the housings then a free-flowing exhaust should be fine. Those that have problems with the ports not opening once the ehaust is freed up usually have sticking actuators or sleeves.
Download the NA EFI chapter of the factory service manual from www.fc3s.org to learn how to diagnose and fix this system. Look in the contents under "Auxilary ports".
Old Apr 24, 2003 | 08:41 PM
nonameo's Avatar
**-P I drive a miata.
heh. might want to look into building something to make elec. ports. Although as far as I know people have tried that with either difficult or no success.
Old Apr 24, 2003 | 08:47 PM
J-Rat's Avatar
Alcohol Fueled!
Split Air Tube
Wouldnt that be a SAT instead of a SAP?
Jarrett
Old Apr 24, 2003 | 08:48 PM
1987RX7guy's Avatar
Notice how some of the younger members resort to flaming when they get upset? Anyway... The auxillary ports are not evil, they are your friends, and the reason why 6-port NA engines make a lot more power than earlier 4-port ones.
You insult us what do you expect. and it is expected for me to be a bit immature since I am 18
Old Apr 24, 2003 | 09:31 PM
nonameo's Avatar
Wouldn't the aux ports take longer to open w/ free exhaust? Backpressure would build up sooner w. an obstuction there like a cat. I think the biggest problem is that they do not open when the time is optimal, even though enough back pressure may be created with a free flowing exhaust.
Old Apr 24, 2003 | 09:41 PM
marcus219's Avatar
FC Mobsta
