I wana know how to do a auto -> maunel swap and know the work involved
Old Dec 25, 2002 | 11:15 PM
Mephis's Avatar
well i relise auto trannys suck thankyou , you make me wana wreck my car, so i wana know who is $400 gona put in a t2 tranny? (used) and how i would mount the Cluth peddle and what all i would need to buy , you know , im not a very fluent person with working on rotarys , v8's is only thing ive ever done major stuff on ,heres what i wana do , i wana junk my auto tranny (sell to junkyard or even trade for a maunel) and get all the stuff for the maunel that i would need to strip from car (i would like someone to list every think , im gona print this all out incase i ever do it, if anyone here knows how to do it plz take the time to tell me thankyou!
Old Dec 25, 2002 | 11:27 PM
Mephis's Avatar
ppl you just scared cause you dont know how to do it and everyone keeps tellin me to do it?
Old Dec 25, 2002 | 11:35 PM
Mephis's Avatar
i ran 4 serches and i ran out of keywords and couldnt find anything about this , so could anyone who say autos are gay plz tell me how to change it unless your gay...
Old Dec 25, 2002 | 11:43 PM
Mephis's Avatar
so everybody gona look and not tell eh? well atleast give me a website or the email of someone that will help me with it , i wana go down to the local rx7 tunning shop (o lucky me i live by a shop that makes rotarys go fast) and see if i can work in there garage , or help em big time and see if i can get 30% labor prices off
Old Dec 25, 2002 | 11:59 PM
rx_7_driver's Avatar
do a search on my name i just did the auto to 5-speed swap on my car
-Shawn
Old Dec 26, 2002 | 12:19 AM
SonicRaT's Avatar
Super Raterhater
if you're going to swap to a turbo tranny, here's what you need:
Brake/clutch pedal assemby
clutch master cylinder
turboII slave cylinder
new hydraulic hard line/soft line as it's better to use new ones than the old ones
turboII flywheel/clutch
turboII transmission
turboII driveshaft
turboII differential
turboII halfshafts
You *can* avoid the TII driveshaft/rear-end/ and halfshafts using either 1) the automatic driveshaft (i don't suggest it because it's a tad bit short, and it's not a very strong differential. 2) get a custom made 3) use a NA transmission and save yourself some time
Old Dec 26, 2002 | 12:23 AM
SonicRaT's Avatar
Super Raterhater
Oh, I forgot to mention, the tranny mount's don't line up so you'll have to fabricate something to mount the transmission to, in my case I had Kevin Landers drill me a peice of angle iron and send it to me and I bolted it to the bottom of the automatic crossmember and then bolted the 5 speed to the angle iron using the top half of it's crossmember (the rubber mount part with the long bolt through it) I believe Kevin has a write-up on his site, http://www.rotaryresurrection.com
Old Dec 26, 2002 | 01:42 AM
https://www.rx7club.com/forum/showth...ht=5speed+swap
these should help some i hope , i used the write out on http://www.rotaryresurrection.com for mine its very good and handy to have it printed out and in the shop with you while u r doing the swap
-Shawn
Old Dec 26, 2002 | 09:54 AM
Mephis's Avatar
i dont think im gona mess with it , the tranny just boliting up was scary enough , custom fab ..., DEFERNTAL no way ... unless they make a bolt up maunel tranny and thats all you need size you know the pedal assimably im not gona do it ...(cant spell)
Old Dec 26, 2002 | 09:56 AM
Mephis's Avatar
theres gota be another way ... like a toqure onverter , stall speed converter (makes the brake act like a cluth and allow you to rev up to 4000rpm and reless brake and launch , if anyone knows were to buy one tell me plz
maikelc
Aug 24, 2015 11:04 AM
pzr2
Aug 15, 2015 08:29 PM
